Car wont lock with key or remote
Hi all I'm new to this forum any help would be appreciated. Own a 2002-3 S Type R and having issues with locking it. Can't lock the doors with the key or the remote. Not sure whats wrong. Put the ket in the door and can't turn the key. When i try and lock it with the remote like normal the car doesn't accept any signal. Tried changing the battery not luck. Searched forum all to no avail.
Hope to hear something cause the car is sitting outside unlocked.
regards
Joe
regards
Joe
Only one key and only one lock on Drivers side. Never used the key once in the 3 years I've owned it. Did start unlocking a couple of months ago after i armed the alarm. So I deadlocked it every time i locked it that seemed to stop the disarming of the alarm and locks.
regards
Joe
regards
Joe
In the event you are in a similar position (only 1 key, etc) with a future car, may I suggest you don't fail to plan ahead and instead check key works in door locks, get 2nd key etc.
My feeling is you'll have to get a jag dealer to figure this one out and it'll cost money you might have avoided had you not ignored the issue for 3 years.
As it turns out its got nothing to do with the key and everything to do with the lock the key fits into. So it would not have mattered if 1 or 10 keys. Are you suggesting I should have been unlocking the car with the key instead of the remote? I still am not entirely sure what your refering to! What is entirely predictable? your manner really sucks mate!
joebit: I've heard of the ignition cyl. going bad, but not the door cyl. Anyway.. Here is what I would do. Take the car to a dealer or Jaguar service center and have them trouble shoot the alarm / remote locks. I say do that first so if it needs a new module then you may be able to save some dough by getting the locks; keys from a salvage car. Check with the dealer on how hard it will be for them to program used keys to a new module and if you need the original module for any reason. This may not be the best way. I would definately talk with the dealer. A good service department will be sympathetic to your desire to save money and should be able to help... I know mine would.
Hi Joebit,
Have you tried putting some lubricant into the door lock and then trying it? Also, the door lock can go bad or the key may be worn enough so that it doesn't engage the door lock properly. You may want to get with the dealer like Jeff said to do some troubleshooting. As I recall, a new or re-cut key will run around $100 or so. Not sure about a new door cylinder though. There may be a mechanical fix in addition to a remote or alarm fix needed.
Good luck,
Mike
Good luck,
Mike
My car is being repaired by a smash repairer at the moment so I can't try the boot but thats great advice thanks v8 (Why didn't i think of that). Your right I never used the key once till now. I did deadlock it with the fob. But your right checking the boot will really isolate what the problem actually is.
Will post the outcome ASAP.
regards
Joe
regards
Joe
msdg137
09-16-2015 06:24 AM
SingBlueSilver
08-27-2015 02:20 PM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
