car won't start
Have a 2005 jaguar s type V6 car will not start or crank over lights all come on even tried jump starting it still nothing. The reverse lights are on and when someone walks behind it it beeps to let me know someone is back there shows its in park could the linkage be off and it be in reverse? That would explain y it ain't starting need some advice on if this has happened to someone else and where I need to start please and thank you
The starter won't engage unless the transmission thinks it is in park or neutral. Try this:
Foot on the brake
Key to on
Move the shift lever until either P or N illuminates (the lever position should agree with the indication, but not so if there is a problem)
Key to start
If the engine now turns over, something was wrong with the shift lever, the shift cable, or the neutral safety switch. The next step will be figuring out exactly what. Remember to keep your foot firmly on the brake, as it may start in gear.
Make sure you get the P or N light on first before turning the key to start. If you hold the key to start and then move the shift lever around, the PCM won't let the starter engage. It has to see P or N first.
Foot on the brake
Key to on
Key to start
Could be the trans / car are unhappy about what gear etc is selected and if so it's usually one or both bolts loose/missing that hold the shift cable to the trans side (get under car, follow shift cable with your eyes and see where it fastens on). Small, about 8mm, just need to be snugged up usually - but sometimes one/both fallen out.
polarisnavyxj
08-16-2016 08:31 AM
Ronnyrhodes
08-14-2016 01:43 PM
