car won't start randomly
Ok guys..I'm getting crazy frustrated here and hoping you can give me good advice. My wife has a 2002 S-type R that we've had on the road about a year now. Unfortuantely, she's only driven it a grand total of maybe 6 months inbetween trips to the shop. The problem no one can seem to figure out is that it occasionally won't start. It cranks, but not starts. Most often, when it does this at all, it has trouble once or twice but then will catch no problem after that. The only code i ever had was the P0420 which I replaced the catalytic converter and that went away. The shop has experienced the starting problem but it's too random for them to see it consistently. They had the fuel pressure gauge hooked up as well as that little wire that shows spark. Stopped by the shop last week, we tried it together and no start first attempt. He said he was seeing no spark. I was thrilled! We actually saw a problem. But today he told me he hasn't gotten any further because they try it every day and it always starts. I know that. The issue is too random to catch it every day. But when it's a problem, it's a problem. Isn't there something the shop could be looking at to see why we got no spark even when it's not acting up? We're never going to get a consistent occurance of the starting issue, it doesn't do it. BTW, since I've had the car, I've done plugs and coils, new battery (which tests fine and holds charge no problem) and new fuel filter. Sorry so long winded, but it's been a long ordeal.
Received 2,193 Likes
JagV8 (06-29-2011)
Received 9,011 Likes
"Did I really fix the problem? or is it just not acting up right now???"
thanks guys. i appreciate the input. yes Brutal, you are correct, i have it at an indy shop. as it turns out, on a separate issue, i also have a cat sytem fault message that showed up after another shop replaced my tie rod and control arm (hmmm...) and that guy isn't standing by his work. anyway the new guy is taking my car to the dealer this week to get diagnostics on that. sounds like i should have the dealer run additional diagnostics for those codes the generic scanners can't pick up? even though i have no check engine lights, etc.? what should i ask for? anything specific?
you can have all kinds of codes without check engine lights on. just make sure they dont clear codes and then see what comes back. while this is fine AFTER you reach a certain diagnostic point, some techs thinks that a first diag proceedure. and many extended warranty companies try to get out of repairs by saying "well lets clear the code and drive it and if it comes back we'll pay for the repair" they know that many codes for cel's and not always hard faults and just pisses us and customers off. your biggest problem is its not a hard fault. and this can lead to alot of time/$$$ spent. you really need to know what codes like U codes,(communication) P codes, etc... see whats there. Realize you probobly wont get a hard quote or repair for a check out fee. Many issues like this run alot more involved. But then you might get some info that will help to get it fixed quickly
If this were the case (causing the PATS system to kick in) would it cut off the spark? I would expect that scenario to cut off the fuel pressure, as most similiar sytems do. Pressure at the rail is fine when this is occuring. Or am I wrong about how the PATS system works?
ok all, promised to post when there is more to tell. unforunately that's not much. dealer picked up no codes at all. having my guy switch it over to standard shocks (see other related post) and going to have to wait and see about the random starting issue. luckily it's a very random issue and always catches on the 2nd attempt (so far). Bought the car private and never had a spare key. Going to order one up...can't hurt even though it's expensive.
Hey kgrosse,
I know it's 3 years later but would love to know if you or (anyone for that matter) ever found the source of this issue it's happening on mine.
Symptoms:
Insert key(I only have one)
Turn key
Car doesn't crank - (red alarm light does stay on)
Dashboard lights on
Keep trying steps above until cranks and starts up.
It's intermittent. And iv'e taken it to a shop and they couldn't find anything even said they tried to start it 40 times and it did every time. When the day before I was trying to get it to start for 10 mins before it did.
Symptoms:
Turn key
Dashboard lights on
You have a different car so it would be worth your time to start a new thread.
But what was missing from both problems is what the red light on top of the dash is doing? This is the PATS light for the passive theft control.
It is NOT any of the dashboard lights you are looking at.
Is it on?
Is it flashing or solid?
Does that change between having the key on to when you actually crank the car?
Is it on?
Hey kgrosse,
Symptoms:
Turn key
Dashboard lights on
Symptoms:
Turn key
Dashboard lights on
If so, try pulling the 10 amp blue fuse. No. 19 in the fuse box near driver's feet. This will prevent the steering column lock from working and the car will start reliably. If it is not showing steering column locked on the panel then you could try it to see. Your car is the same model as mine and pulling out fuse 19 won't effect any other important electrics (other than the steering tilt mechanism).
Although this is only an interim repair it is better than your intermittent non start issue and it will send you towards the purchase of a new locking mechanism.
There is also an issue with a failing battery which cause odd faults that are mentioned quite a lot on this forum.
I hope this is a help with your issue.
tbird6 - thanks I started a new thread |https://www.jaguarforums.com/forum/s...5/#post1066173
Paul792 - No, it doesn't show "steering column locked"
thanks all, I started the new thread here https://www.jaguarforums.com/forum/s...5/#post1066173
Does it have a "steering column locked" warning on the control panel?
When we replace an INSTPK we MUST configure it NO STEERING COLUMN LOCK FITTED.
bob gauff
Paul792 (09-29-2014)
Hello my name is chris and I am having a problem with mine similar to this one. One day I was getting off of the freeway and it stalled out when I made a left turn kinda fast. I messed with it for a few checked wires no luck. I sat in the car for a few and it started randomly on its own. I drove it home. It said engine stall again as I pulled into the drive way. I replaced the fuel pump. And still no luck. Its getting fuel and spark and seems like it is something so simple. And its bugging me. I really like this car and dont want to get rid of her. But at this point im at a stand still
