Cat converter and codes
how can i no for sure if the cats dead?
i dont really have the time or space to take the cat off the car, its snowing in the uk as well lol.
i have a code reader which does live data so i can read the o2 sensors, but dont know what im looking for?
Er, P0102 is a problem with the MAP. PCM uses it to help it get fuelling right.
edit: Sorry!!! It is MAF. grr. Dunno what I was doing.
Your car is the older type (pre 2002.5MY / 2003MY USA), so all 4 O2s are the same type.
Both upstreams should switch fairly often from high to low and back. STFTs should wiggle to cause it. Both downstreams should hardly move and do it less often. The banks should be very similar.
You need them HOT to have them happy so idling isn't really ideal. Rev for a minute or two and watch. I think they'll go on switching if you let it go back to idle but may largely stop as they cool. Cats don't do much unless HOT also, especially old ones.
Think ugly sine wave if you want an image.
I hope a tech will chime in if I've got this misleading as the last time I had a car with these older type O2s was some years back!
darren-talbot (01-17-2013)
Aus V8S
11-13-2015 11:01 AM
rachelstr
09-03-2015 12:59 PM
