Catalyst System Efficiency Below Threshold
Keep getting this fault code. I have purchased a autel autolink and I'm fairly impressed with it do far. So I have cleared the fault but it comes back after about 3-5 days.
Anything to worry about?
Possible causes?
I have a 6 month warranty on the car not sure what it covers or how to proceed putting car into garage. Do garages mind if you read your obd yourself? They might say they don't trust my equipment lol.
Possible causes?
I believe this means the car thinks the catalytic converter is not working, but think this code can be triggered by a faulty o2 sensor.
What was the exact code ?
As for the warranty ring and speak to the garage, the problem you might have is i was under the impression that cats were a "wear and tear" item and might not be covered, like tyres, brake pads and windscreen wipers
darren-talbot (12-10-2012)
Received 2,643 Likes
There are four oxygen sensors that compare the exhaust pre and post catalyst. If the reading is the same, the ECM sets off the MIL assuming the catalyst is no longer functioning.
I have found the best approach is to begin with inspecting the connections and then moving on to replace the oxygen sensors. You may also want to try changing fuel as has been suggested in a previous post.
darren-talbot (12-14-2012)
Jaguar Forums Editor
Jaguar Press release
09-10-2015 05:08 PM
