Catalyst System Efficiency Below Threshold Bank 1 & 2
There is a product called cataclean that you pour in the fuel tank...I have used it before with success...your cats may be beyond help though if too much raw fuel went through them...I do not know how to physically inspect a cat converter....maybe using an infrared thermometer and comparing to heat specs
You can look for exhaust leaks that way...see if there are visible soot marks...exhaust leaks cause problems also...the air leaks Jagv8 is referring too would be intake or vacuum related....the easiest and most thorough way to diagnose these is by doing a smoke test...this test introduces smoke into the engine's intake and vacuum systems under pressure and you look for escaping smoke...ask your mechanic about it, or a dealer if you prefer...it is not a dyi if you do not have the equipment....more than likely the smoke test will reveal your problem areas and pending the results more advice can be given
Received 2,652 Likes
DTC P0420 = replace catalytic converter after correcting over fueling fault(s) on Bank 1
DTC P0430 = replace catalytic converter after correcting over fueling fault(s) on Bank 2
There is no magic fix for failed catalysts with melted cores. Unburned fuel ignites inside the catalyst melting the honeycomb structure.
NBCat (01-11-2019)
from what I remember reading, it should take about 100 to 200 miles of varied driving.....but, you need to make the suggested repairs before anything will return to satisfactory readings....as NBCat stated...once the converters have been melted the only fix is to install new ones...I would go to an exhaust shop and at least have the converters looked at by a specialist....with plugged and /or melted converters, you run the risk of a fire starting at the converter because of extreme heat produced
You can see it for yourself on a working car - yours isn't - as the trims start at zero.
KenAdamson
34
07-04-2017 11:27 AM
darren-talbot
12-13-2012 07:57 PM
mtfife
03-08-2010 11:59 AM
