Catalytic converter delete
That's not high mileage (km-age?). If they're plugged something else has been badly wrong to cause it. Get a decent OBD tool and look at the O2 waveforms, check for codes, fuel trims, etc. Whatever has been wrong probably is still wrong and needs fixing. Apart from risk of severe engine damage you're probably down on power. What's your fuel economy like?
There are plenty of previous posts about this, as well as some O2 sensor data I posted.
get spark plug anti oil foulers with the same thread size as the 02's and take out the downstream 02's. Screw in the foulers then screw the 02's into the back of the foulers. This spaces them out usually enough to get them to think the cats are cleaning the stream
You can get dummy O2 sensors also. Pretty common on other performance cars. I don't know if you would need a specfic one for a Jaguar or not. Take a look here. Also known as a "O2 Sensor simulator"
http://www.o2simulator.com/?gclid=CI...FRCdnAod3Hp7oA
My thoughts exactly, we replaced the cat on a Ford 6L diesel for the same sounding symptoms, exhaust manifold leak cyclically, and considering a full tank (app 7/8 used) is yielding truck like mileage... Fuel and air filter are done, fresh coils and plugs this summer (all 8), no codes to be read, noted exhaust exit delay on start up (4-5 seconds before seeing tailpipe exit (cold Calgary))
The O2 fooler puts thing into perspective, and after it was explained that the OBD2 reader can plot the voltage and frequency of the current setup, we should be able to figure out if they are actually functioning properly before chop/cut/reweld
The (2002) facelift cars have wide-range sensors upstream. The earlier cars probably do too but I'm uncertain.
Wide-range don't switch frequently. Most articles on the net assume the older type of O2s. They're used downstream, and shouldn't switch much if your cats are OK (especially if the fuelling's good). You want fuel trims to be no more than about 10% (pref. 5%) on each bank (add short+long trims) when running CL (closed loop).
Blipping the throttle or causing an air leak should make the upstreams flick - and rapidly - if they're OK.
O2s (especially the upstream) live in a hideous environment so can degrade, get poisoned (bad oil etc) or break.
edit: the original cars (1999-2002.5MY) do not have wide-band (aka linear aka AFR) O2 sensors
O2 Simulator, E-commerce
Thinking about doing a cat delete as I'm hearing it's somewhat common for the cats to clog...
What are the laws? I know it's generally illegal, state enforced...Is it legal for an exhaust shop to fab up bypass pipes, test it in the shop for leaks, remove the bypass pipes, put the Cats back on with the bypass pipes in my trunk, I leave and install the bypass pipes in my driveway?
