CATS/Adaptive Suspension
Can anyone tell me how to disconnect the adaptive suspension/CATS from Trunk? Is it a fuse or relay? I know I need to install 4 new standard shocks first. Also I know ADAPTIVE IS AWESOME! Just need to use something cheaper for now, shocks are way worn out and needs it.
The module is in the trunk - left side.
There are 2 harnesses - disconnect both (you will have a permanent CATS Fault message on your dash.
I personally advise against disconnecting the harnesses from the module...
If your looking to disable the shocks only than disconnect each of the connectors from each shock.
Again, you will have a permanent CATS Fault message displayed and the Amber light I believe...
To clarify my previous post:
If you have a fault, you need a dealer level reader to read/erase the code.
If you disconnect the 2 connectors from the ADCM module - the CATS Fault and Amber light will go away.
abonano (03-06-2015)
dmatthewman
09-30-2015 10:10 AM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
