cats system fault dash message
first of all i want to thank all the people that helped with the miss firing issue, i pulled the covers seen that a tensioner had been replaced, chain was kinda loose, pulled off front engine cover, wow, had 2 cracked sliders, rest of tensioners were shot, bought timing chain kit, tool, engine runs smooth now, really good, the only problem left is the cats fault, i checked the wiring in trunk, and module, looks good, no water, wring nice too, checked the the wiring to the front shocks, looks fine .....closet dealer from me is 65 miles...is there suppose to be wires going to rear shocks as well?, or just fronts....car runs excellent, but ride is rough , stiff, not smooth....if i was to replace all 4 struts, and not use the dampening system just disconnect in trunk, any suggestions on what name struts to use, looking for smooth ride.....any help is appreciated
thanks again for all your help
05-03-2006 12:08 AM
