CD Changer won't play non-factory CD
I could swear I saw this thread somewhere, but searching didn't find it, so if this is a duplicate, I apologize. Maybe somebody can move it to the right forum. My S-Type CD player (both the 6 pack changer in the trunk and the in-dash single) won't play my own recorded CDs. it will play retail. The screen either says 'No CD Loaded' or it indicates playing, but no sound. The counter moves as if it's playing, but that's it. So I'm not sure if the unit was never designed for non factory CDs or there is a problem with either the programs I'm using to create them, or the format I'm creating them in. I'm formatting them as MP3, and they work in every other application, i.e., laptop/desktop MP3 player. The unit appears to be working, but not being any kind of expert, I can't say for certain. Any advice greatly appreciated. Thanks.
It won’t play them because it can’t play MP3. If you just copied the CD as a CD it would play that but when you format it as an MP3 you need an MP3 player. Heres a post I found https://www.jaguarforums.com/forum/x...3D-mp3-193657/
davidladewig (12-03-2020)
CDs were originally designed as an audio only (with a *tiny* bit of metadata) format. I haven't tried anything but standard audio CDs in my 2000 and I wouldn't expect the factory CD player to recognize MP3. There might have been aftermarket auto CD players that would play MP3 in 2000 but if I recall correctly it was the late Naughts before it was common.
I don't know what software or OS your using but there's plenty of cheap or low cost software that will convert MP3 to Audio CD format (Google it) and you'll have to resign yourself to only having 80 minutes of music per CD in the car.![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
I have several fairly high-end music converter programs that can convert into almost any protocol format such as AAC, WMA, AC3, MP3, WAV, M4A, FLAC, AIFF, MKA, OGG and even Apple's priority M4A and M4P, and none of those formats will play. I wasted 10 CD-R disks burning the same 30 songs in 10 different formats and inserting the disks and none of them played. I even used the same format as the retail music disk and it still wouldn't play. There has to be something written to the retail CD that I can't copy over to a blank that the system needs to read in order to play. Thanks for all the feedback.
Wish I could tell you what settings I used. Nothing fancy, just the basic copy and burn functions on a PC running Windows.
No. These are all music files bought and downloaded from iTunes, then converted to MP3 files. About 1700 all told over the years. I've converted the MP3 files into other formats because everyone here is saying MP3 won't play on the system. I've tried all the different transfer methods from creating a music CD to straight music file to CD transfer without the fancy software interface to Data Transfer to straight copy from music folder to CD. Nothing works. I've done this for years converting the files to MP3 and playing them everywhere but in the Jag. Slip them into the Ford Edge CD and they play just fine.
Every CD in my CDC is a disk I have burnt myself on a PC from a MP3 file. They all work fine.
My guess would bre that whatever you are burning the disks on is not finalising the CD.
Have you tried the CD's you have made in another normal CD player?
They are all standard CD audio format.
Mellow
Mellow
Thanks for that. I was burning them as a music cd. Using Roxio Creator NXT 3, I have the menu choices for Burn MP3 CDs; Burn Audio CDs; Burn Data Disc; Create Disc Music Projects. Evidently using anything but Burn Audio CDs puts non readable metadata on the disc the car's player can't read. Some will actually activate and show on the screen as "playing"... the counter even moves, but no sound. All the other options show up as "No Disk". Using the Burn Audio CDs option worked. When I burn Music CDs, I and get 70 or more pieces on the CD. Using this option only allows 30 and they all show a (track_1 [thru 30].cda) file name on the disk with no artist info at all, but they play. Even loaded the CD changer with 6 and they all play. Just don't display song info or album art on the screen.... but then, I don't know if the player is capable of displaying that info. Thanks for all the advice.
kr98664 (12-06-2020)
kr98664 (09-10-2021)
Factory made discs are much more robust. The homeburnt ones have a weaker reflecting side that can weaken in time.
I realised the same, that my x202 stacker in the boot would not play mp3 but was unsure what format I had to burn in for it to work. No I know it's in 'audio CD' format.
Can anyone answer if that type of file has any other name, or just simply known as an 'audio cd'?
The cd player in the dashboard however does play mp3 burnt discs that I burn from mp3 Windows Media Player files but not sure if I have the option to convert files from Windows Media Player to 'audio CD' or any other format from mp3 stored files.
When these files are on your PC (when you've copied a CD or 'ripped' a track) they're stored as a .wav (for WAVE). There are two types of file that use 44.1 KHz, 16-bit, stereo & these are WAVE & AIFF. I hope this helps. I should add that a decent audio program can convert .wav to mp3 to ac3 to wav & so on. <EDIT:- Good luck converting .wma (Windows Media Player) files to anything else.>
You say your dash CD plays mp3, so I'm going to try an mp3 CD in the single CD player on my STR tomorrow, but I'm not hopeful - but if it played mp3's on yours I'll give it a try (I know the changer won't play them) but I DON'T use Windows Media Player. There are also different types of mp3 encoding. The one I still use is based on the original Fraunhofer codec & is tweaked to correctly place the stereo.
