CD player keeps ejecting CDs
Hi all!
Tried to search the forum for solution but didn't find any.
Here is the problem:
CD unit below the touch screen keeps ejecting discs. For example, I start the car, load the CD, drivimg for 15-20min, turn off the car, start the car again and CD player ejects the disc. I put the disc again, CD player tries to load it and after 20 seconds disc comes out. After I leave the car to cool down for 10 min, CD player works normaly. It seems to me that the CD player is overheating or something.
Does anyone had similar problem?
Thank you in advanced for your help!
Disc which I'm trying to play is copy in wave format, since mp3 is not supported. I have also noticed that Verbatim discs are better for reproduction then Traxdata. I will try tomorrow with some original discs and see what will happen. But I think I will need to install ACM.
Thank you all for your help!
It may not be that the copy disc wasn't burnt correctly, but some CD players as they get older will only play original CDs - not copies, as the burn is different & the player can distinguish the difference. I have a great sound system in my Acura that stopped playing copies that I had burnt but will still play originals.
I was referring to the laser itself. Laser can exhibit some weird problems when they start to get weak. Examples would be you unit will play some discs but not others, the player tries to load but the laser can't read the toc on the disc. The throwback reference was only to show that a laser continues to get weaker and weaker as it is used.
07-09-2018 01:44 AM
FS[Western US]: JAguag x350/358 CDC Player Brackets
perezal
12-24-2015 04:20 PM
