Center console latch on STR gave, how do I force open w/o damaging car?
The center console cover latch seems to have broken. When I pull the latch handle, it feels slightly limp, and only allows for me to slide the cover back to expose cup holders, or slide it back to its forward position. I plan on repairing this when I get around to it, but for now I need a lot of the things I have inside my center console. The man in me just wants to tear it open with force and strength, but at my age (35 y.o.) my brain is actually starting to consider consequences and is stopping me from doing so so I do not cause any $$$ and unnecessary damage to my car's interior.
Does anyone have any firsthand knowledge as to how to open the broken center console cover without breaking anything else? Or can one of you guys open up your center console and just kind of think and look for a way that it could be opened up without the assistance of the latch handle? Thanks everyone!
UP:
I just looked at mine. There are two latches on either side of the lid that fit into indentations on the inside of the cubby box wen you slide the lid back to reveal the cupholders. If you remove the cupholders (pull straight upwards) you there will be enough space for you can shine a flash light into box and look at the underside of the lid. I think that , using a long thin screw driver, you can get the one of the latches to retract, which does both at once. The lid should then open.
Under Pressure (10-30-2011)
andy303 - THANK YOU SO MUCH!!!! Yes your idea worked! I was able to open my center console up and get my belongings from the inside. While I had it open, I tried to figure out how I can fix all of this but I do not have much time today so I just shut it for now to look at later. But yea, I used a long screw driver like you said to get in there. Its hard to see but its about three inches behind where the cup holders are. I had to use a bit of force and I could only do one side at a time. So I would pry one side where the latch was, then I would stick my finger in the gap to keep it open, then I repeated on the other side.
I won't know until I have time to remember to call Jaguar dealership next week. Problem is, when I get to work its a non-stop rollercoaster til I leave for the day so it may take til late next week before I remember to call them for a price. But I will post a price after they quote me one.
2006 xj8 console not opening . I slid the arm rest to the rear and pried at the front corner . Three inches back from the corner are the tabs to release the pivot function . A scribe or small blade screwdriver pushed in released the spring loaded tabs . Remove the 4 tt10 torx screws to reveal two cables that operate the slide and pivot functions . The cable end (barrel) had pulled out . I snapped the barrel end back in and the arm rest worked . Thank all of you for your help! Catricks
BrentGardner
28
04-26-2024 03:08 AM
PinnacleWax
Detailing / Car care
08-26-2015 11:44 AM
