Central Locking
Central Locking
Haven't found looking on here my problem with the central locking. Whenever I use the fob or interior lock button all I get is the sound from all the doors but none will lock or unlock. Can manually lock each door separately or unlock driver's with key. So of course it is a hassle to lock my doors now, so I don't. I need to fix this, but what is the part that needs replacing and I would try it. Have no idea how to troubleshoot this electric lock system compared to the easy of my Mercedes vacuum systems. Help, please.
When you first start the car and drive away, do the doors automatically lock then? This was an option enabled or disabled by the dealer, but I believe enabled was the default. It would be pretty rare to find a car with this automatic function disabled, unless a previous owner requested it. On my '02, once I reach about 5MPH, the locks all activate.
If the door locks kick in normally when you drive away, that should give us an idea if the locks are capable of responding to a single command.
This is a strange fault!
Just to be clear if all the doors are unlocked and you then drive at over 5mph the locks make a noise but none of the doors lock?
Plrease note that using the handle on the inside will unlock the door so when testing the auto locking you will need an assistant to test this from the outside as pulling the handle inside the car will just unlock the door.
The locking does not alow you to lock people inside the car!
Did the car always do this, is it somthing new or is the car new to you?
By the way you have missed out the 5th digit on your VIN number. It should have 17 digits.
You have a USA spec. 06 model year (made in 2005) 3.0L petrol.
(The 5th digit will tell us if it is an auto or manual stick, my guess would be it is a 'A' so a LHS auto, but it could be a 'B' LHS manual.)
Mellow
Mellow
"Just to be clear if all the doors are unlocked and you then drive at over 5mph the locks make a noise but none of the doors lock?" Correct!
"Did the car always do this, is it something new or is the car new to you?" Yes, bought the car about 3 months ago and had problem when I bought it.
+1 on that!
Just thinking out loud, but I wonder if one of the lock actuators is drawing too much current. If so, perhaps the control module is programmed to quickly remove power to all locks instead of continuing to try. Maybe that’s the brief noise you’re hearing.
Do you see any difference in behavior or noise between the four locks? I’d try unplugging the oddball and see if the other three now behave properly.
That sounds like it is is way too long! The noise should last about a second.
I do wonder if this is an aftermarket modification of some type?
Perhaps an aftermarket alarm system?
Mellow
Mellow
Take a look at this thread:
https://www.jaguarforums.com/forum/s...ics-faq-65657/
It shows a LOT more details than you may need at the moment. The thread shows how to remove, repair, reinstall, remove a second time, and finally replace the door lock actuator. For now, you're only concerned with unplugging the actuator, so you can skip much of the details.
The connector uses Ford’s infamous sliding red lock, which has to be released first. You'll be working by Braille, so here’s a quick video explaining the process:
Meanwhile, I gets to thinking. No charge, so don't be worried about getting a bill. You mentioned you hear the actuators running at all 4 doors. Here we are trying to figure out some common failure mode that would cause 4 good actuators to misbehave. What if you had 4 bad actuators? Could be the previous owner didn't care, and did not nothing as each one eventually failed. Read through that thread above, and you will see how the actuator has a plastic gear prone to breakage. Maybe do a recon mission on one actuator, and see if the gear is indeed broken. I don't know if it can be inspected in situ using a small mirror, or if it has to be removed.
I mention the possibility of 4 bad actuators as a coworker recently went into a panic when both headlights failed on his car. He is a top-notch troubleshooter, and was trying to figure out some common path affecting both sides. His car had a fairly complicated system, with separate control modules for each side, a data bus, relays, etc. I think there was even some rope and pulleys. He was looking at possibly several hundred dollars' worth of parts. After much headscratching, I asked him when was the last time he confirmed both headlights had been working. Turns out one bulb had failed previously and he never noticed it until the second bulb failed and left him in the dark. The moral of this tender heartwarming story?: Two things, actually - I was right, and don't overlook the simple possibilities.
https://youtu.be/Y-AJ41jA0U4
I turned off my automatic locking as I have the SDD and just did not like that auto lock.
Tom in Dallas
TBB
TBB
The following 2 users liked this post by joycesjag:
jazzwineman (11-06-2021),
S-Type Owner (12-08-2021)
I wonder if there is some control logic causing the lock actuators to continue running until at least one provides feedback that the locked position has been reached. If none reach the locked position, perhaps the lock command will time out after X number of seconds. Just a thought.
