central locking...open all windows,close all windows
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
hi again...
i have some new infos about central locking especially if u want that your windows will open and close from your keys
because i ve tooked off battery,when i wanted open and close windows all at once...didn t worked...after a lot of research , i ve found a good solution...so how to do it:
1 u need 2 keys
2 put one key in ignition in position 2(all light in dashboard,before the engine will start)
3 other key put in door knob
4 press boot to open
5 turn key to close car
6 turn key to open car
7 take off key from door knob
8 switch ignition
9 hope it worked
1 u need 2 keys
8 switch ignition
9 hope it worked
Jumpin' Jag Flash (04-19-2015)
Location: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
My fob can only activate global open, not global close. Global close only works by pressing the button on the console.
My question is...how did OP figure out this rather unusual way of programming his fob to perform both global open and global close using 2 keys, opening the boot, switching ignition on/off, etc?
if global close is not working,before performing this reset of keys,try and make your windows to open and close by one touch(that means to get into your car,start engine or put keys in ignition position 2,take each windows ,one buy one.
press the button up until u hear a clinck,after that push button open until u hear clinck(and the windows is down),if u heared bought clincks....then ...when u will push a short (button)up,the window will go up itself.
after all windows will go up only by one touch,then try again the method with 2 keys described on thop of the topic.
hope this will help.
I am having difficulties with the directions, can anyone provide a more detailed explanation of the steps ? My global open (open windows/sunroof) by holding the key fob unlock button while it is not inserted within the door or ignition works fine.
My question is will this procedure unlock the ability to close all windows and sunroof by holding the key fob lock button without having to insert the key in either the door or the ignition ?
99xk8guy
06-05-2023 06:28 AM
