chaffed wiring to DCCV
Guys, as I write this I am sitting at the dealer (yeah I know) no one has been able to isolate my issue with hot and cold air from the AC. Dealer has been all through it to confirm what I already knew. DCCV is good, RCCM is good, brand new Evap Temp Sensor... They now believe it is a chaffed wiring harness and are trying to locate the effected area...
Does anyone know where I can point them to save labor time trying to find the damaged wire(s)???
Thanks in advance!
Thanks in advance!
They should be checking what's going on with the plug to the DCCV. Is something open or shorted? Do you have the full 12VDC at the correct terminals? At the correct time when the climate control button is pushed?
Too vague when they say wires chaffed. The wire bundles are behind the front bumper and inside the front wheel well liners. Might not have a good ground too?
Help!!!
Well... after sitting at the dealer all day today they have determined it was not a chaffed wire... They replaced the DCCV test drove the car and its still going in and out of HOT / COLD... The Evaporator Temp Sensor has been replaced, the RCCM has been replaced, the DCCV has been replaced and the relay also has been replaced...
They had 3 mechanics on it this afternoon and needless to say my car is still at the dealer tonight... They were nice enough to give me a loaner (2013 XF) at their cost, I say that was the least they could do, after we sat there from 9:00 - 5:00pm...
They are testing everything out with a voltometer and there is one guy under the hood and two in the car...
Anyone ever have an issue like this? Any ideas, Brutal you out there have you seen this before??
HELP!!
HELP!!
Too bad that RCCM didn't solve the problem, but at least its off the list of potential parts to change! Only long shots I can think of at this point are a heater core flush (worth a shot) or maybe blend doors (again, long shot). Any chance you have tried the three temp sensors in the foot wells? If these are acting up I believe they can cause problems. I replaced all mine a while ago. There cheep and easy to replace. Again, worth a shot!
I just drive around no heater now. Mine works for about 20 min a month. I have an electric plug in heater that cost $40 and always works. Once I hear of your solution Ill look at mine again. My Nissan Navara has started doing the same with the CC. Works for 20 mins then cold only for the next few hours. At least its still in warranty. Paul
They did say that the new DCCV was working but its the same issue as before so I am not keen to pay for a replacement DCCV when it wasnt the issue... DO I make them put the old one back in and not pay the $716 they wanted for that repair?
They also have tested my RCCM and say it is doing what it should... OF course it is I had it professionally repaired last time to add the diode in to keep it from burning out the trace on the PCB the next time the DCCV fails...
I had the Evaporator Temp Sensor changed and that had no impact. I changed out the relay thinking maybe it was bad but that also had no impact. They have traced all of the wiring and now say that is good. ll that is really left are the remaining cabin temp sensors and the actuator flaps in the heater box...
Interestingly enough, they did say that even after changing out the DCCV that the AC compressor was not kicking on initally, but it was working as of last night. What would cause the compressor not to kick in... hmmmmm... Some sort of temp sensor or possibly an induction fan not working properly???
I sure hope they dont plan to bill me by the hour for their voltometer testing...
Anyway, anyone have any other thoughts on this, I did clean the temp sensor in the dash behind the ignition switch it was dusty but not really clogged that also didnt help...
It was 93 and 100% humidity the other day and my car is blowing 110 degree air from the side, rear and floor vents and 70 degree air from the center vents...
ARRGGHHH!!!!
cbharley10 (06-18-2013)
**update**
Okay coolest Dealer experience EVER!!!
Got a call today from the serivce manager at my local Jaguar Dealer... He started off by telling me that mine was one of the cleanest and nicest 03 STRs he has seen come through the shop! He then proceeded to appologize for the 4 days my car was in the shop and the mis-diagnosis of the DCCV valve. He said they should have been able to detect the issue and since the problem wasnt with the DCCV that the $720 replacement (Parts and Labor) was on the house!
They finally were able to determine that the issue was as I had thought a chaffed and broken wire (the power lead) to the DCCV. It took roughly 4 hours of labor to troubleshoot and repair the broken lead. My car has been vaccumed, washed and is now ready for pick up at a cost of just under $500 bucks!
I have to say I am very impressed that they owned up to the mis-diagnosis and ate the costs of the repair. I now have a new DCCV, Evaporator Temp Sensor, RCCM and a freshly repaired and insulated wiring harness!
Looks like these guys deserve some serious credit for their honesty and integrity!! If anyone needs service and is in the Cincinnati Area, please call and talk to Tony at Cincinnati Jaguar / Land Rover!!!
Happy Motoring!
Happy Motoring!
Hi manycars
Not sure of the exact location, but my Indy said that have to take the front bumper off to get at it, so I assume that it's where the loom from the DCCV goes through the front and along behind the bumper. Not much help, but I recon it will be obvious once the bumper is off.
Good luck.
Good luck.
