Change 2 bad coils or all 8?
I have a 2001 Jag S type 4.0 with 115,000 miles. I found out the valve cover gasket was leaking and I have 2 bad coils. I was told that you only change coils when they are bad but I have also read just change all of them. Should I just change the 2 or should I change all 8?
what brand of coil do you recommend?
I always just carried several coils in the car but I had dozens of good-used coils from working at the Jaguar dealer.
When one failed I would replace it and move on.
I would buy DENSO 6736004 which is likely the OEM part or MOTORCRAFT DG529 that is likely the same part???
The OEM yellow or green label parts seem to fail and the OEM black label parts (issued later) seem to last longer.
bob
bob
bob
bob
Stick with a quality name brand. I think I went with Motocraft but can't remember for sure. Stay away from Fling Dung and similar bargain brands you might find on eBay and other sources.
mikchek (08-15-2018)
The rearmost ones need a bit of wiggling.
I would only change a coil if absolutely necessary as they seem very good quality. (I have a spare I've not yet needed i.e. am still on the OE ones.)
I wish I would have just followed my gut and replaced all 8. I replaced the 2 and now the others are starting to go bad. ugh
WillieE
05-17-2011 11:14 AM
snooktarpon
01-13-2009 07:47 AM
