Changing plugs and coils on a 3.0 V-6
I have a couple of random misfire codes on my 2003 S-type with a 3.0 V6. Looks like I need to change the plugs and coils, right? (105,000 miles) Can anybody tell me what I need to buy to complete the job? Don't I need to remove the intake to access the plugs and coils? Will I need intake gaskets? Any others? Where's the best place to buy the parts? I was thinking www.rockauto.com. Which coil packs to buy? They list a bunch of 'em.
Thanks in advance!
"EZ"
Thanks in advance!
"EZ"
I am doing this, this weekend. I found the best place to buy was Rock Auto. Below are the parts that I bought for my Jag:
Spark Plugs (Iridium) x6
Ignition coils x 6 (part # uf435). <=== you don't have to buy this one, but make sure it is 4 wire plug.
Upper intake Gasket - Fel-Pro MS96494
Lower intake Gasket - Fel-Pro MS96485
Fuel filter - Fram G8018 (if you have never done so)
Also,
IMT O-Rings
Also see this thread for additional info:
https://www.jaguarforums.com/forum/s...tenance-49309/
Hope this helps.
Also,
IMT O-Rings
Hope this helps.
hawaiiansurfster (01-01-2013)
Taken from the FAQ post, lots of good info there!
https://www.jaguarforums.com/forum/s...ics-faq-32135/
https://www.jaguarforums.com/forum/s...ck-pics-49214/
www.rockauto.com only lists the lower intake manifold gaskets. Are the upper intake manifold gaskets called something else? Anybody have another source besides Jaguar?
Thanks.
Thanks.
Jag is purring like a kitten...best part is that there is no more oil leak from the flat IMT O-Rings. I have a K&N air filter coming in the mail and that should round out my tune up and repair job. In total I replaced a shot rear hub bearing, both sides of my front upper and lower ball joints, put new Michelin Pilot MXM4s, and the other items I previously mentioned.
Wes Steenrod
09-06-2015 06:52 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
