changing premium sound system in jaguar 2002 stype
No easy way. I've considered using a dead donor head unit just for the connectors. There is no aftermarket adapter kit nor wiring harness for the premium sound units. Only option, without ripping everything out and starting over was to use a Monster (or other high quality) cassette to mini plug adapter, and connect a Harmon Kardon BT10 Bluetooth interface, which actually sounds quite good. This forum also has a dedicated Audio section, but no one has successfully replaced a premium sound head unit with a more modern one.
BTW, I'm originally from The Bronx! I miss the food.
to this
its hard to know what advice to give .
i know nothing about the early 98-2002 model.
but if its the later then yes it can be done .
just reverse the steps taken in this link .
https://www.jaguarforums.com/forum/s...ed-pics-77246/
you will need to change it from this
to this via the reverse steps in the link ,
then finally to this
or which ever head unit you require ..
i don't know why you would ! the stock premium alpine actually cranks !
with some minor work .
if you heard mine you might re think and just upgrade your speakers and add a high level to low level converter for RCA to an amp and sub . it works great .
i also added the veffbox for clear music streaming . and that alone bought this sound system in to the two thousands .
if you want a list of my upgrades to the sound system I'm happy to share part no#s .
I agree that even after 16 years after my Jag was built, the audio still kicks big time, even if an extra tweeter could help. Tom Tom handles the sat nav, and that cassette adapter isn't bad either. Most importantly, I didn't have to pay $65,000 dollars for an Audi A6 to get a great sounding unit!
Changing the interior color scheme would be a deal breaker for me.
Datsports (06-13-2017)
what do you mean by a donor unit? can you dive into specifics? I mean if I am taking my premium sound unit out couldn't that be my "donor unit" or are you referring to the wire harness? if that is the case can't I just order another wire harness?
10-30-2023 09:05 AM
JimC64
03-02-2015 08:07 PM
