Changing rear brakes
bklynchris (05-17-2013)
No, I tried pulling it up and down with the engine running and I get the same message. I dont think the key was left in as I told them specifically to take the key out.....but I can and probably should get the battery checked. I'll check the how to's to see how to recalibrate. Thanks
Found this on the forum a little while back and added it to my "Jag notes".
EPB Reset (use switch to disengage EPB BEFORE changing pads!)
a. Switch off the ignition.
b. Disconnect the battery for 30 seconds.
c. Reconnect the battery.
d. Start the engine.
e. Firmly apply and release the footbrake five times.
f. Confirm that the message ‘NOT CALIBRATED’ or ‘APPLY FOOT AND PARK BRAKE’ is displayed on the instrument cluster
message center. This indicates that the parking brake is in calibration mode.
g. Lightly press the footbrake pedal.
h. Apply the parking brake by using the EPB switch.
i. Release the parking brake.
j. Release the footbrake.
k. Confirm that the brake warning lamp is no longer illuminated on the instrument pack and that the ‘NOT CALIBRATED’ message is no longer displayed in the message center.
l. Apply and release the EPB five times to ensure no error is present.
The following 2 users liked this post by Robinb:
bklynchris (05-17-2013),
Corv (04-18-2014)
philwarner
09-05-2015 10:05 AM
innzane
09-02-2015 10:08 AM
