Cheap Brakes (Wearever)
Needed to get new front brakes done for my 2000 S-Type 3.0
Car has done 130k miles and is the family daily driver. I've had my fair share of issues with the car, and we're tired of pouring money into it. But I still need new brakes, so I went and got a set of Wearever rotors and pads (Silver semi-metallic) from Advance Auto Parts for $60. Had a family friend install them $50.
The way I thought of it was, I replace rotors every time I do brakes (Jaguar recommends not to cut rotors), so why overspend on rotors that I'm not going to resurface? I was thinking about ceramics too, but a decent set cost $100. No matter what brakes I get, I'm sure it's the last set I will ever get.
Almost 1000 miles in, and I have to say the brakes are pretty good. For daily use, they do the job. Very smooth. Not as much stopping power as I'm used to and I have to push the pedal a little harder than before to get the same stop, but overall they work well. For $110 total, I'm happy.
I will admit however that they create a monumental amount of brake dust. At 1000 miles, my front wheels are covered in dust. I'm kinda digging the "I'm too busy and important to care about washing my expensive European sports sedan" look though...
Jumpin' Jag Flash (10-16-2013)
I'm finding pads last at least 40,000 miles (*) and rotors much longer. I'd be surprised if an STR has brakes that last longer than your car!
(*) they were on the car, part worn, when I got it and still don't need replacing
Received 9,010 Likes
Most people won't notice the difference between cheap and quality parts until they need it most and it isn't there. I don't understand why you wouldn't want good stopping power; safety items like brakes and tires aren't things I would want to cheap out and take a chance on.
Wearever is Advance Auto's house brand. It generally has favorable reviews across many different forums of cars. They are listed as OE replacements, and the pads even come with a lifetime warranty. I would hardly call that bad.
You probably got the Golds, which have been known to produce less dust
I don't see why you replace the rotors every time. You'd only do that if at or below minimum thickness.
Received 2,263 Likes
My dealer told me to never resurface them. Always replace, because of how heavy the car is, you wouldn't want to compromise stopping power with thinner discs. My mechanic also told me the resurfaced discs are also more prone to warping and cracking. Considering it's $30 to resurface, might as well buy the new rotors ($40) and have a peace of mind...
One of my others cars (non-Jag) has ~130,000 miles on the rotors and is on set #4 of pads.
JimC64 (10-17-2013)
Never said I wanted crap brakes, just cheap ones. Cheap doesn't always mean bad, nor expensive is always good.
4/13/2014
Quick update. Brakes are still holding up well. Smooth as glass. No problems to note. In fact the amount of brake dust has decreased considerably. I'm guessing after the initial break in period there's less dust. Overall still very satisfied with the purchase.
xjrjag
09-24-2015 10:08 PM
