Check Engine Light
P1111- Intake Air Temperature (AIA) intermittent high voltage low temperature condition
- loose connection
-open circuit
-faulty AIA
P1646- RH O2 sensor
-short to ground
-short to power
-open circuit
-high resistance
-faulty O2 sensor
O2 sensor located on drivers side (US) the one before the CC
maybe sensors are bad
- loose connection
-open circuit
-faulty AIA
P1646- RH O2 sensor
-short to ground
-short to power
-open circuit
-high resistance
-faulty O2 sensor
Wrong! (sorry to be blunt) P1111 being a P1 code is manufacturer-specific so you need to look it up with care. For jag & Ford it means that the monitors have completed OK and thus is normal. The alternative would be P1000 which means they have not completed - and then you need to find out why (maybe you recently cleared codes or disconnected battery).
P1646 really is an error, however.
First thing: do NOT make assumptions.
Second: codes are best viewed as hints. Only sometimes are they a direct diagnosis.
The meaning of a P1 can depend on the exact year etc of your car, though that tends not to happen much. I am using the 2003MY tables.
Please note that RH is defined to mean: as viewed looking from rear towards front of car.
In this case, it is indeed bank 1 i.e. the RH bank. The upstream (pre-cat) sensor. Or its wiring, or... Remember - view the code as a hint!!
Having to type this at speed so hope I've got it all right
BrentGardner
28
04-26-2024 03:08 AM
