Check Engine Light on!!!???
it is bolted to the front of the throttle body. That code normally means replacing it. It is a roundish looking valve with a small electrical connector going to it. Sorry I can't be more descript than that. But it is on very front of throttle housing area close to intake manifold
I had the same problem, the check engine sign turned on. So I took it to the dealer and it ended up being a hold fuel filter, I wasn't told I was supposed to change it every 30,000 miles even if I was I only put 5,000 miles on the car since I got it. But long story short warrenty didnt want to cover it and i was left with a 600 bill to fully clean the system.
BrentGardner
28
04-26-2024 03:08 AM
