check engine light removal
Is there a way to remove check engine light without a obd tool. I have had codes read which told me all 3 cylinders on the passenger side were misfiring.. I have changed the coils and spark plugs.. but still have the light.. ok want to reset and see if it comes back.
Some codes are removable by disconnecting the battery for some time (usually 30+ minutes to drain all keep alive memory). Some codes are hard codes and will require a scan tool. You could always call around or swing by a local shop and see if one of them is generous enough to turn the light of for you for no charge since it shouldn't take more than a couple of minutes.
Some places won't do that as its against the law in some states. Of course, one could always ask the employee to just borrow the scan tool or there's always the "Hey, look over there!" and then clear the codes.
It's funny you say that because I had a parts store guy tell me that once. I can't find anywhere that it's against any law to erase the codes?
Maybe there is but I can't find it. I finally figured out the guy simply did not know how to do it. I showed him on the reader and then it was no problem.
For troubleshooting it seems almost a must to be able to clear everything and start over.
Jumpin' Jag Flash (02-06-2015)
Ok, got it scanned again today.. no more misfire codes.. only p1646? And p1000 .. what is this? Auto zone had no info for the p1646.
If it's not too much to ask.. can you take a quick picture of its location.
Hi, if it wasn't the dead of winter here I would be more than happy to provide a pic - but it's chilly outside. The O2 sensor you need to change is the one that comes right off the exhaust manifold.down pipe going to the converter.
This is what you need (if you have a pre 2002 car):
But I see now that you don't. Sorry.
