Check Engine Question
I have a Jag 2005, S-type, 3.0 46K. Zero problems of any serious nature.
I put in a new battery and reconnected. When I first started it- everything seemed fine except for resetting parking brake and that was simple. I then decided to clean the air filter and obviously had to remove the Mass Air flow sensor. I put in back together and started to drive the car and had an error message (restrictive engine performance- i assume limp mode) and then realized after driving a half mile that I had failed to recoonect the mass Air Flow sensor and then did so and went back to normal mode, but had a check engine light, but no apparent problem and no error message.
It is a broad question to ask, but having done nothing else to the car- i am a little stuck.
The only thing i noticed that was different or sounded different was when i turned the key on or off and started and turned off the car there appeared to be a slight clicking sound in the key turn on and key turn off in the area of the throttle body and when I put a stethacope on it, It seemed to be in the area of the throttle position motor. I had not heard it before and the throttle body sounds fine.
is this type of amber light dangerous or is it something the car will clear after it runs through a couple of hot -cold cycles.How do you reset the codes manually to clear and see if it comes back?
Tom in Dallas
Tom in Dallas
Tom in Dallas
Tom in Dallas
good luck
If I were to buy a scanner, what do I need to work correctly on the Jag. I know it needs to be an ODB II, but they also make reference to a "can" ( of which I know not)
Another question;; when the battery is disconnected and the system drained, does the ECM and TCM have to relearn or do any of the settings remain?
Tom
If it was just the MAF, the light will go off after 3 (maybe 2) drive cycles (i.e. engine cold to engine hot). The code will remain stored for 40 or 80 but harmlessly.
There's no need to clear it but you've confused it. If you want to speed it up, clearing with an OBD will NOT do it. You can clear the code(s) that way but it will NOT change its learning.
If you do want to speed its learning (even though there's no need), you have to disconnect the battery. No, that won't affect the TCM. It will affect the PCM and it will start re-learning.
It may also affect the EPB (park brake) but the forum (and handbook) cover that.
The best value OBD tool is an elm327 ($20 or so on ebay). A far better tool is AutoEnginuity but it's more like $450. Search here on those 2 tools for more info, as covered often.
Your car has lots of OBD networks. Have a hunt for the circuit diagrams in jtis ($10 ebay) if you want a surprise.
I think you 'll find that cheapish Innova does not do what you hope. Especially on a jag. For OBD they are NOT Fords!
Feel free to buy and come back with what it does
But take a look at the huge coverage of AE. Just about every sensor on every module.
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
![Icon Teeth](https://www.jaguarforums.com/forum/images/smilies/icon_teeth.gif)
Another cool thing which I like about it, is that I can get Accurate temperature read outs of my Transmission when I'm doing a Transmission fluid change, thats just one of many plus points with live data features it has.
No one is judging at least I don't think.
There is only so much data a generic obd2 scanner can get from our cars.
If you want abs bcm tcm and other module data you MUST have more specialized tools.
I myself need to monitor iat2 which is a sensor which measures charge temp for the air after the blower which AE is the cheapest one I could find to do it. That's a pretty specialized sensor that can't be read in I think mode $02 (don't quote on the mode. I don't remember all of them off the top of my head)
The SG as I recall lets you define a small number of custom PIDs so you could in theory read more but the large snag is that you'd need to know the magic values for the PIDs. Overall it's so much easier just to get AE if you want more data.
I used a friends Innova 3130 on my Jaguar STR, and it does what it says it does, works flawlessly thats the reason I recommended it
, I'm sure AE works just as good, but don't judge something that you haven't tried ![Icon Teeth](https://www.jaguarforums.com/forum/images/smilies/icon_teeth.gif)
Tom in Dallas
Tom in Dallas
The amber light and "restricted performance" is much different than "limp mode". Basically, amber / "restricted performance" means there is an immediate issue but the car can still drive. Red warning light and "limp" mode means that the computer senses a catastrophic failure but will allow the engine to idle so you still have brakes and steering.
My car makes the same clicking noises, always has.
BrentGardner
28
04-26-2024 03:08 AM
philwarner
12-06-2021 07:13 AM
