Check engine and Restricted Manuevering with amber and red light
Guest
Posts: n/a
OK i just got this car and drove it fore 3 days before this happend, so i got it home and it wouldnt drive faster than 70mph, now i turned the engine on the same evening and the amber lights are gone but the check engine is still there, i went to autozone and picked up a vehicle code reader and recieved the following codes:
p1658 - Manufacturer control, aux. inputs, aux. outputs
and
p1111 - manufacturer control, fuel air metering
Do i need to bring the car to a mechanic :-( , or is this something easy i can fix.... Also the code reader says erase codes, should i do that?
Any help is greatly appreciated and thank you in advance.
and
Guest
Posts: n/a
Jag_genius
For some reason all the lights and check engine icon went away(thank god but still worried, dont want this to happen if i go on a long drive).
Which code was the throttle relay on failure(and what does that mean exactly?) and what does the other code mean?What can i do to make sure this doesnt happen again? should i change the throttle relay switch, where is it located? ECM wiring would be harder to do cause i'll have to trace out the whole wiring from the computer to the throttle(accellorator pedal) correct?
FYI: Sorry if i seem a little off on what i wrote above, i'm not a mechanic but can usually figure things out if i know whats going on
Thanks for helping and working with me on this :-)
PS>>> If you need any help with a computer definelty let me know, that's my field :-)
p1111 is just a normal code... readiness code...
p1658 is the throttle relay on failure...
if it's a intermittent problem.. then i wud start with replacing the throttle relay.. .. it's electromechanical on switch that delivers power to the throttle body .
BrentGardner
28
04-26-2024 03:08 AM
Robert1968
06-24-2017 11:16 AM
