Climate Control not working - Communication Fault
My climate control stopped working (2003 STR with Nav). The radio works and all other functions appear to be OK, but when I push the climate button I get a message on the screen that reads "Communication Fault Consult Dealer". Check engine light is on, code is P1699 which is for the climate control. I inspected the RCCM and can't see any burnt traces. I used the electrical troubleshooting guide on JTIS (attached relevant portion for reference) and everything checks out except for the following test where I get a reading of 60 ohms;
B9 : CHECK FOR CORRECT BUS TERMINATION
1. Turn the ignition switch to the OFF position.
2. Disconnect the battery negative terminal.
3. Reconnect the climate control module module electrical connector, FC028. 4. Measure the resistance between the diagnostic connector FC001, pins 006 (Y) and 014 (G).
Is the resistance between 50 and 70 ohms?->
Yes INSTALL a new climate control module module. CLEAR the DTC. TEST the system for normal operation.->
No Goto
Now for the questions,
Has anyone else had this issue?
Is there anything else I should do before trying to find a replacement RCCM?
JEPC says that there are several part numbers for the RCCM, my VIN is M44664, the next part number starts at VIN M68300, does this mean a module from a later VIN won't work?
An ebay seller selling a RCCM says that the module needs programmed to the car, I have not heard this anywhere else, is it correct?
No Goto
AaronD81, before you go too much further, have a look here...
- JaguarClimateControl.com
... There again, maybe you already have. These guys are good.
My problem probably fits in this category...
Not all climate control modules are repairable ? what? gasp! - JaguarClimateControl.com
P1699 fault and other issues. Help!!
Hi
Although, been a member of this helpful site for some years, this is my first post(question) so not sure if it is in the right place.
My brothers S Type (2005 3.0) had the dreaded hot air continuously blowing through vents, so the DCCV was replaced and a used heater control module sourced, same part number.
After taking the old one old and connecting the replaced unit I did a quick test and all seem to be working correctly, so I put all the trim back together. I then went to switch on again.
The blower no longer works, on the instrument panel a Park brake fault comes up also cruise not available, The electronic brakes are stuck on and will not release when in gear.
When switching of ignition and removing key the front lights come on and stay on, also the petrol gauge still shows fuel as would when in operation.
I have checked all fuses and pulled all relays out, as I suspected a sticking relay, but no difference. disconnected battery for some 12 hours and no difference. Battery now disconnected as lights would come on !
Can't even take it anywhere as brakes are locked on, my code reader shows P1699.
I re installed original heater module and now that one does not even blow hot air, as if no power, when ignition is switched on there is a clicking sound coming from instrument panel for about 10 secs.
Any thoughts, help will be gratefully appreciated.
Tony
Tony
Last edited by Roulette666; 01-23-2019 at 12:04 PM. Reason: wanted to put 'thanks' in
I'm not sure anyone will know. (I doubt it needs programming/etc.)
Has the RCCM got good power, ground, etc?
It may be worth either getting your own Jag diag tool (Mongoose JLR + IDS/SDD) or a shop with one to see if the RCCM can be detected/etc. Depends a bit on the used RCCM price.
Hi
Tony
Tony
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
