Climate Control problems
This link provides a little information on the heating system and it should help JagRepair.com - Jaguar Repair Information Resource I should note if you are low on coolant or you have an air pocket in the coolant system it will give you the same symptoms.
A238 (04-03-2012)
Hi. Thanks for the replies.I've be able to work out my fault is
with the actuator situated on the top right of the clmate conrol
box. Can anyone tell me how to remove it.Pictures would be great.
I went to the local dealer and he frightened me with talk of money-
lots of it- to get this fixed, so I thought I'd have a go myself.
Any help greatly appreciated.
Cheers- John
Cheers- John
If you use the link you will see photos that you are looking for. But be sure it is your DCCV before replacing.
Cheers- John
Cheers- John
A238 (04-03-2012)
Thanks All for the response. JagV8 asked what evidence for the diagnosis: (and bear in mind I'm new to this) I took the car to a Jag Dealer and paid them to put the
dianostic computer on it. The information that came back was that the
Airduct chamber – Part # XR832147 was at fault. When I asked for more information i was told that the 'Top right hand actuator' had failed and that if i could find a replacement, it would be a way cheaper option.
That said, I'd be very happy to find I didn't have to get in behind the dash.
Any thoughts? Cheers, John.
Received 6,327 Likes
Chances are they will be right.
I think you will find this thread interesting, https://www.jaguarforums.com/forum/s...-me-out-49227/ It could be worth checking the sensors before diving in too far, it does help if you resemble a Chinese contortionist!
A238 (04-04-2012)
I'd read the info that has been linked to earlier thoroughly before you dive in.
Still growling here, lost my mate a while back and retired the X300 with the driver window inop, now battery has gone bad from inattention,, Just picked out a '02 Model S for a new love, got a decent deal, pristine titanium with climate control issues, was either hot or cold lo got the A/C freezing, anything else was heat, defrost and vent changes work as intended, now we have another hot spell and no cold air on lo temp setting only outside air with a whiff n puff of blend door heat (so I think) I first thought that it was the blend door, and now that I have been driving it for a week (I now have an extra, extra, extra, extra car), the cloth car wash took the mascot off, (replacement cable needed) So do I go back to the Town Car or do I make tracks and get this A/C going? (I like the bigger car but this one is nifty and noticed even here in Hollywood) aruggh. The boot lamp is inop, not the bulb, and the same for the fog lamps. Lemme at it, Any suggestions from ye minions of the Cat?
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
