Code 16 Occupancy seat sensor - Obsolete Part RESOLVED
Hi Folks, i have a 2002 STR that has a code 16 (B2290) and Reads: Occupant Classification System Status front passenger side.
The part I'm told by Jag Dealer and a few UK independents that this part is now obsolete. I have located one breakers nearby that has one priced at £90 (includes module too)
Has anyone had this issue, done the change out, and solved the problem?
If so what sort of job is it and i am likely to be successful in eliminating the DTC if the replacement part is good?
Btw. I have tried to resolve the problem by taking the seat from my other STR (2006 model) and whilst the seat fits in OK, it throws a code 15....i suspect that is to do with the seat controls which are slightly different....I will ignore that option.
Seat Ready for inspection
I believe that this is the sensor threading into the seat cushion base
Sensor connector
I got hold of a occupancy sensor bypass - it doesn't work though. code is still as was
Sensor connector
took 20 mins to get this out with about 10 screws or so
Made by delphi
update: Now got the seat sensor pad out...took only 20 mins to do..it is a DELPHI product. I gave them a call all to no avail...but the guy said that they made them all very similar to other cars so its a try and match part number parts numbers he said as the XF(other cars in Jag range) part may do the trick and you should be able to get a new one too...indicative price is circa £400 which when you consider what it does seems fair...but then it is plastic and electrical so seems excessive but then we've been there before with excessive pricing !!
I wonder if a Land Rover part from the same era would work.
Is that an air-filled pad with a pressure sensor? Has it sprung a leak and deflated completely? Just trying to get an idea how it works.
Strictly guessing, but I think it works on air pressure. Again a guess, but let's say it's precharged to 2 psi. Place one's buttocks on the seat, the pad is compressed, and pressure rises to 4psi or who knows what value. Anyways, the control module expects the sensor to report anywhere from 2 to 4 psi. Should the pad leak, and pressure drops below the precharge value, that would be reported as a fault.
Other possibilities include normal pressure but a bad sensor. Or maybe a broken wire, but such a fault may set a different code. An open circuit fault may be treated differently than a value out of range.
I mention the broken wire because you tried a little doohickey that's supposed to mimic a good reading from that sensor. That may be worth investigating.
In the meanwhile, i have sourced and ordered (from a breakers @£70) a replacement unit that will fingers crossed .....do the trick and get the light off the dash....for my MOT in a few weeks.
Got me thinking that if they had pressurized with air (like you say) and placed a shrader valve on it you could check air pressure any time, but i guess that was an avoidable extra expense and therefore not designed in. IMHO It may have been worthy of consideration....but who knows what they had thought.
Just a thought, since the pressure of the buttocks is translated into an electrical signal, have you connected an ohm meter to the connector of the Delplhi Seat Sensor Pad and put pressure on it to see if there is a change in resistance? As someone else noted, it may be an electrical issue elsewhere.
Back to morning brew . . .
FWIW, I think Delphi really messed up calling this an Occupancy Seat Sensor. If I was in charge, I’d have called this a Buttocks Sensor. If nothing else, it would be fun to visit an auto parts store and loudly ask for one.
beulahjag (05-04-2019)
I have been on the forum long enough to read some rare troubles, but yours is the first i have read concerning the seat sensor....MOT must be a bear at times from different posts i have read...it does make safety as important as emissions...i like that...wish the states here would impose something similar...it would weed out the junkie cars and i don't give a damn attitudes....good luck in your hopefully successful repair....never seen the underside of our seats....wow, there is a lot of electrical and moving parts
I was looking at your earlier pictures of your car's buttock sensor (that's the official name now). You mentioned it was filled with gel. Is that everywhere, or just the smaller coin-sized bubbles?
What about the two triangular sections I've highlighted below? If I had to guess, I'd say those are the only two compartments connected to the pressure sensor via the elbow in the middle. Are those two triangular compartments filled with gel or air? The third triangular compartment below the elbow seems to have two holes punched in it, so I don't think it does anything.
The Buttock Sensor
The Buttock Sensor
The Buttock Sensor
The Buttock Sensor
An Apology
Looking back over this thread, I now realize it was inappropriate for me to repeatedly refer to the buttock sensor. This was wrong of me and I apologize wholeheartedly, without reservation. I hope you can find it in your heart to forgive me.
From here on, I shall use proper grammar and refer to this.component as the buttocks sensor. After all, nobody has just one, at least as far as I know. The plural version is thus appropriate, as two (or more) is the standard minimum ratio of buttocks per person (BPP).
https://www.dailymotion.com/video/x6qglec
beulahjag (05-07-2019)
Thanks also to Brutal for advice re the Sdd/ids plug in to re-calibrate. I have to locate someone nearby that can do that for/with me (or a dealer)...I now have the mongoose cable and the software to load but haven't gotten hold of a good enough laptop as yet that can run it ok..
The requirements to run sdd ids are not rigid... anything over the bare minimum works great...i run version 130 with xp and 138 and 145 on windows 7 32 bit beautifully, all on an older dell d620....i just swap out hard drives for my particular version that i want to use
Thanks for helping on that. I have to get that a priority. As there is only 10 day until MOT test i doubt ill have the chance to get my own up and running so will seek someone local.
However, whilst writing this the part from the breakers just landed so i will give that a try and see. If not then its back to what Brutal has suggested and SDD hook up
The official name for this is ‘occupancy sensor’ the last part number for STRs before vin N13089 was XR856952 this replaced XR837898 and XR844490.
Have you tried contacting the official Jaguar Heritage parts?
See this link to the official on-line Jaguar part catalogue. Use your vin number to select the exact part and then use the ‘contact us‘ link to enquire about a part.
https://www.jaguarclassicparts.com/u...ing/front-seat
They may well be able to help you, but be warned this an expensive part. The later one that is still available is £651.51!
See this extract below from the official Jaguar worrkshop manual. This will explain why just changing the sensor will not sort out the problem.
Front Passenger Seat Occupant Classification Sensor
• NOTE: The front seat occupant classification sensor is serviced as a calibrated assembly.
Individual components of the front seat passenger weight sensing system are not serviceable. The system must be replaced as a complete
unit and due to its sophistication, each replacement system requires calibration, so to avoid the need to provide calibration equipment to
each dealer, a pre-calibrated service kit is available. The following components are combined and calibrated during manufacture to form the
front seat passenger weight sensing system:
Passenger seat cushion
Silicone filled bladder
Weight sensing control module
Pressure sensor
The weight sensing control module is mounted under the passenger front seat. The silicone filled bladder is integrated into the seat cushion
and the pressure sensor, which is attached to the bladder, is mounted under the seat
The silicone filled bladder responds to weight changes on the passenger front seat. The pressure sensor responds to these pressure
changes and provides an appropriate signal to the weight sensing control module. The weight sensing control module processes the input
signal received from the pressure sensor and makes it available to the RCM via the controller area network (CAN). In addition, the weight
sensing control module performs self-diagnostic functions on the system, with any malfunctions being notified to the RCM accordingly.
The front seat passenger weight sensing system responds to the occupancy of the passenger front seat in accordance with the following:
Passenger front seat status 'EMPTY' — Passenger air bag status 'OFF' — Passenger Air Bag Deactivation (PAD) indicator 'OFF'
Passenger front seat status 'OCCUPIED' (small occupant) — Passenger air bag status 'OFF' — PAD indicator 'ON'
Passenger front seat status 'OCCUPIED' (large occupant) — Passenger air bag status 'ON' — PAD indicator 'OFF'
The SRS via the RCM, monitors and processes data from the front seat passenger weight sensing system and several other sensors before
making a deployment decision. Malfunction of the sensing system or associated circuits will cause the SRS indicator to illuminate.
Pressure sensor
