codes c1165 and p1234 help
Old 03-15-2011, 02:24 PM
joycesjag's Avatar
Received 1,702 Likes on 1,211 Posts
A code that is P0332 or P0333 would be an indication of the LH (left hand) knock sensor which is located under the intake manifold, best to ask dealer which one they are replacing.
Also if they pull the intake are they going to replace the 6 upper intake gaskets? One other thing you should inquire about are the IMT O-rings, they are located in the manifold and are a known problem that should be replaced as well as long as the intake is off.
Old 03-15-2011, 02:27 PM
xsinbadx's Avatar
Rick, Just confirming that bank 1 is RH passenger side? Just saw that on the jtis.
Old 03-15-2011, 02:37 PM
JagV8's Avatar
Received 4,520 Likes on 3,931 Posts
Yes. RHS. (Passenger side USA. Driver side here.)
Old 03-15-2011, 02:38 PM
xsinbadx's Avatar
Ok, well i know for sure it's p0328 so if that's the rh then no intake manifold removal. It's not a jaguar dealer i'm at so i kinda have to guide them. Aftermarket knock sensor ok, or should i pay the premium for one from the dealer?
Old 03-15-2011, 02:44 PM
joycesjag's Avatar
Aftermarket should be fine.
Old 03-15-2011, 02:47 PM
xsinbadx's Avatar
Thanks for your help. I'm on it!
Old 03-15-2011, 03:12 PM
xsinbadx's Avatar
Shop keeps telling me its the upper sensor, not the lower. They gotta be wrong? wanna charge $485 to do it.
  #28
Old 03-15-2011, 03:32 PM
xsinbadx's Avatar
I told them to replace the rh side. They must be crazy. You saved me a lot of money Rick. Thanks
Old 03-15-2011, 05:40 PM
joycesjag's Avatar
Man $485.00 thats a chunk of change, a Jaguar dealer is probably that. Does your shop normally work on Jaguars?
  #30
Old 03-16-2011, 12:24 AM
xsinbadx's Avatar
It's not a jag dealer, its actually a toyota dealer. $485 wouldn't have been my final price cuz my friend is the service manager there and usually cuts the price by 20% for me. I take it there for basic stuff. Any serious jag problems i take it to another place that specializes in imports. No more jag dealerships for me. They said it was a 3 1/2 hour job to replace the top knock sensor removing intake manifold and replacing the gaskets. I confirmed your findings of the lower knock sensor with the other place i go to telling him i was doing it myself. So i told the toyota dealership to just replace the bottom one. My guess is that they didn't know which one it was so they were going to do both. I will let my buddy who is the service manager what happened cuz that would have been over a $300 mistake. I'll probably just stick to just brakes from these guys from now on.
philwarner
25
06-26-2021 05:43 AM
bdboyle
09-16-2019 05:58 PM
Terry H
07-04-2017 05:48 PM
JCam
10-23-2016 08:27 PM
philwarner
09-02-2015 11:45 AM
Quick Reply: codes c1165 and p1234 help
