Codes p0300, p0301,03 and 05.
Misfiring codes on the V6 models are often caused by the two factory Intake Maniford Tuner Valve O-rings failing and allowing oil to seep out of the IMT valves. Search this forum using the phrase "IMT valve O-ring leaks" and you'll have plenty of reading to do. Then, wipe the bottom of your IMT valves with a clean white paper napkin. If fresh oil shows up on the napkin, you have likely found the source of your codes. New O-rings are an inexpensive and relatively easy DIY fix....
philwarner
25
06-26-2021 05:43 AM
KarimPA
09-27-2015 08:46 AM
