coil change
coil change
I just changed the coil in my Jag. When the car is in park I rev. the engine and above 4k rpm it starts to cut out. When I drive it,it never misses a beat, runs like a beast all the way up to red line.
I never rev. the gas up before in park prior to coil change so I don't know if it did this before coil change.
My question Is there a fuel cut off when in park like a governor?
Ok as usual I freaked to soon.
I was digging around and found out that the jaguar v8's have a rev. limiter on them in park to 4500 rpm's
3.0 will rev. up to 7 k
I also read the 00-02 with the ford tranny has a rev. limiter on the v6's.
But removed it on the ZF trannies on the v6's
This is good to know.........lol
Thanks for the reply from what I was reading the rev. limiter is actually to keep you from damaging the transmission not the engine.
This is why they had a rev. limiter on the weaker ford 5 tranny on the v6's and removed it on the zf trannies.
Mugatu
22
06-23-2020 01:50 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
