Coil Pack Failure, Again??
#61
On s types the water gets in through the windscreen trough see message below
![Icon Omg](https://www.jaguarforums.com/forum/images/smilies/icon_omg.gif)
![Icon Party](https://www.jaguarforums.com/forum/images/smilies/icon_party.gif)
After months of hassles ... a solution {for my XType}... my local garage says that the problem is moisture getting into the coils ... but ----- HOW was always my question??? It would seem that the "cowling" if that is the right word has deteriorated around the camshaft cover ... a bit like the lip on a cup, above the handle. It's cracked and flattened.![Icon Fryingpan](https://www.jaguarforums.com/forum/images/smilies/icon_fryingpan.gif)
Local garage advises to get a new Camshaft cover, but really ... that is not the solution. The solution I'd have thought would be to remedy the windshield issue ?? Did you ever get a resolution on this properly ???![Icon Question](https://www.jaguarforums.com/forum/images/smilies/icon_question.gif)
![Icon Confused](https://www.jaguarforums.com/forum/images/smilies/icon_confused.gif)
#62
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
Could you post the link to the Youtube video you mention ?
Many thanks in advance
![Icon Trophy](https://www.jaguarforums.com/forum/images/smilies/icon_trophy.gif)
The windscreen trough leaks water onto the engine in pre 02 models and causing the coils to go happened to me twice before I was told I found a youtube video of how to fix the leak problem solved 5 quid for a tube of mastic is better than 300 for jaguar coils and plugs
#64
What did you do to solve the problem with repeated coil failure way back when.. I'm having the same problem on a 2004 S-type 4.2L v8. I was doing preventive maintenance replacing the coils and plugs at 87k before 100k and now can't get #8 coil to stop failing. Don't fix something that isn't broken. Help anyone.
SD96XJ6L
11-05-2015 10:47 AM
DFW
10-01-2015 07:22 PM
