coils n plugs not problem on the P0305 code.
Consider changing your Intake Manifold Tuner Valve O-rings (IMT O-rings for short). Remove the factory yellow-colored O-rings and replace them with the new-and-improved green-colored O-rings (there are a total of two). Should cost you less than $5 if you do it yourself, and there are several good DIY threads here that will walk you through the process step-by-step. Just search for "IMT O-ring replacement" here on the forum and you'll find what you need....
Eman_usa (12-19-2012)
To add to the valuable advice already provided above - check to ensure the connectors to each fuel injector (especially cylinder #5) is snug and tight - as a loose connection at the injector can flag a misfire code. Those plastic locking tabs on the connectors are notorious for snapping/breaking off...
Thanks everyone,
This is great information.
Today i will be checking and/or replacing #5 fuel injector on passasenger side rear.
Then i will locate and replace the rubber elbow. also the o-rings have already been replaced when i did the coil and plugs..... wish me luck!
also i will be cleaning out lines and looking for any breaks cracks.
thanks,
Eman
thanks,
Eman
Just 4 more bolts remove the lower intake and right below it is the infamous elbow that cracks and needs to be replaced.
This should help:
Jaguar HELP!: Intake manifold in a 2002 S-type 3.0L
This should help:
ok, today i replaced the #5 cyl fuel injector ( passenger side rear near firewall) and cleaned and checked the hoses and lines for leaks.
I took off lower intake (it was very easy with fuel rail.
then i took the elbow off. that was in great shape no problems.
cleaned and checked all other injectors and o-rings.
lets see what happens.
Eman
Eman
Yes i have a left hand drive USA model with the date code of 09 of 01 that is a pre 2002 model year i was going off my dealer info.
could someone confirm the cyl#5 is on the drivers side i would have easily repaired the issue.
haha that would be great. no sense crying over spilt chocolate milk.
Its the midle one on the easy side.
swap it with the one infront if you dont believe me, misfire will jump to cyl 4.
PAGE 14
https://www.jaguarforums.com/forum/a...-spec-book-pdf
PAGE 14
Eman_usa (12-20-2012)
