Complete Brake Failure
2008 S, 3.0 56k miles, purchased new. Replaced front pads. Moved piston back with a C clamp. Did nothing to rear brakes. Didn't bleed or open the system. Started veh, had soft pedal, put into reverse and pedal went completely to floor, pumped pedal three times, each time went completely to floor. By this time I was through the fence and going down the hill....(don't want to talk about this part)....once towed back to driveway veh started, now had a firm pedal,but ABS light was on, Brake light was on and had messages for ABS failure, cruise not available, and I think something like Booster not available.
Restarted the veh. Booster not available message not showing. Drove the car up and down long driveway, brakes were good and after two more starts ABS,Brake light and all messages disappeared. Tested ABS on gravel and appeared to properly operate.
Any ideas? thanks
Any ideas? thanks
Most of your stopping power comes from the front. I'm not sure how the ABS control module came to the conclusion to set the light in your situation, maybe the brake booster pedal travel sensor gave some info to the control module that it didn't like. But in the end your brake system is fine, you just missed a step in the repair.
Received 2,625 Likes
clubairth1
29
05-10-2024 12:57 PM
1964Daimler
09-09-2015 11:28 AM
