Computer says this.
If you're not getting any relevant OBD fault codes, I'd ignore those likely inaccurate calculated numbers. If it's really bugging you, get under the car and take a direct voltage measurement.
Thinking about it a bit more, I'm not sure O2 sensors even use a reference voltage like other sensors do. Two circuits within a modern O2 sensor:
1) The sensor portion itself is a voltage generator, roughly akin to a small battery. The voltage output varies with the oxygen content. No reference voltage.
2) The heater portion brings the sensor up to operating temperature quickly. It's just a tiny electric heater, controlled by the engine computer. Once again, no reference voltage.
Pohara (08-14-2023)
Do you have an infrared thermometer? Quite inexpensive these days. Go for a test drive with a bare minimum of brake usage. On an empty stretch of road, pull over and coast to a stop without using the brakes. Measure the temperature of all four brake discs. If any are substantially hotter than the others, that could be the culprit.
NBCat (08-14-2023)
