Computer screen/Heat and AC control
Hello my friends.
Today, the center screen was blacked out on my STR. I have no control over navigation, heat, fan, AC, or defrosting options. Stereo is fine if I use the CD player below the screen (need the screen to operate the trunk multi-CD, obviously).
The small LCD screen below the main color screen which registers temperature is flashing "C1" and "50" or "51" alternately, and it's blowing low heat from the vent.
There are no codes. I cannot find any posts that resemble these symptoms.
I'd appreciate any input or advice on the fuse number and location for this region if you think it's worth changing.
2003 STR 44K.
Many thanks!
2003 STR 44K.
Many thanks!
There are posts, but the Search feature rejects short things so ignores 51 etc. Really useless.
I put a detailed post about How To Search Better (General Tech I think) that will allow it.
Ah yes https://www.jaguarforums.com/forum/j...le-site-60209/
Scottish Chap (10-12-2014)
1. Ejecting the CD from the drive in the boot and then reinserting, allowing a reboot. Two people with this issue noted the CD would not eject and they had to manually remove the DVD player to get to the CD, and then the problem resolved on re-installation. My CD ejects easily and goes back in. No resolution. This is not my underlying issue.
2. Disconnect the negative terminal for a minute, then reconnect to allow a reboot. I tried. No difference. Same LCD screen error message.
3. Look for the fuse that drives the DVD player/navigator/AC/Heat etc. and replace. I do not know where this is (do you?), but will try it if I know which fuse to pull. I have a 2003 STR wiring diagram at home but I am stuck in the middle of nowhere for 4 days. I do have extra fuses with me.
4. Clean the DVD player with a CD cleaner (not tried this yet).
Some of the above were found in the British Jag forums:
Touchscreen broken? (error C1 50 51)
Any other suggestions?
For anyone that loses AC/heat/navigation control with the LCD screen error codes: "C1, 50, 51", I used the following algorithm with some success this evening:
{nav/dvd unit is in the left side of the boot, you can check the display/touchscreen with ignition key in either power on or engine running position and use this button sequence on the display unit;
NAV & Right Temp. Up, NAV & Right Temp. Up, NAV & Right Temp. Up, Audio, Audio, Audio
It might take a couple of attempts!
From this Display Inspection Menu you can check all the buttons work and soft keys work, 50 51 points to nav/dvd unit requiring an update/reboot from dvd}
I was able to enter the diagnostic mode then get full access to all controls. Other than deleting all my stored locations in the navigation system which is annoying, it has returned to normal even after multiple engine shutdowns. It's clearly more likely a software issue that spontaneously manifested rather than a fuse or electrical issue. Will keep you posted.
![Icon Clapclap](https://www.jaguarforums.com/forum/images/smilies/icon_clapclap.gif)
I've gone in and created new ones, and set the audible chime option for it (very handy for passing landmarks on a regular route to remind you to look for something... or need to be moved over in a lane prior to exit, etc.) - but still, no matter what I do - this functionality just plain simple seems "GONE". -
![Icon Question](https://www.jaguarforums.com/forum/images/smilies/icon_question.gif)
Anyone got a quick fix to this as well?
TIA.
Cheers,
-Grant
PolkNole
05-14-2024 03:36 PM
Camnelson324
09-27-2015 08:48 AM
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
zdrapec
09-25-2015 05:49 AM
