Confirmed Crossed Referenced Ford Parts that work with our Jaguars FAQ
#81
Received 6,330 Likes
The following 4 users liked this post by Norri:
Jon89 (05-03-2014),
Jumpin' Jag Flash (05-03-2014),
Mclovin22 (10-30-2023),
Paula Vecchiarelli (04-24-2020)
#82
The following 2 users liked this post by Razorback31:
#84
#86
#87
Does anyone know if Ford's 3.0 VCT solenoid is the same for this Jaguar. I have had my guys here at a ford dealer try and cross reference XR8E 6B297 AD and they can't come with anything, I was able to get a pigtail for it, WPT-1051 works like a charm.
I may be requiring one solenoid as I keep getting P1381, had followed pinpoint tests and can't find anything wrong with it, so I am suspecting a solenoid. Want to order one, Jag wants 200 for theirs part # XR816-235
#88
Hi people
I have a Jaguar S Type 2001. The clutch was making a noice. Now it stays down and cant change geara at all. Mechanic saya I need a clutch/pressure plate and release bearing.
I hear that Ford V6 parts can be used on jag. Can i buy these part from Ford. Any part numbers know etc
#89
Hi,
I have a de-laminated crankshaft pulley; the outer part has slipped 4 or 5mm towards the block and is causing the belt to squeal (chirp) because the alignment is out (I suspect the belt is the only thing keeping it in place).
Has anybody had any joy fitting an alternative Duratec 30 part?
Mazda, Lincoln, Ford? They all look identical and cost considerably less.
There are even aftermarket parts for the Lincoln that are less than 25% the price of the Jag part but no mention of fitting Jaguar.
The part numbers I have found so far are:
Jaguar: XR854185 (alternatives: XR822546, XR831679, XR83308, W0133-1655491
From the existing part: XW4E 6316
Mazda: MZDS-MPV
Lincoln: XW4Z6312BA
ATP 102355
Dorman 594-514
Any advice (including 'suck it up and buy the Jag part')?
Aidan
Mazda: MZDS-MPV
Lincoln: XW4Z6312BA
ATP 102355
Dorman 594-514
Aidan
#91
jaidank (05-26-2016)
#92
#93
Location: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
According to Evan-Fischer Auto Parts on Amazon.com -
RH Front Upper Wishbone Arm (Jag Part #XR852090 superceded to #XR856012); and
LH Front Upper Wishbone Arm (Jag Part #XR852091 superceded to #XR856013) fits:
Up to 2002 Jaguar S-Type Base 3.0L to VIN #M45254
Up to 2002 Jaguar S-Type Base 4.0L to VIN #M45254
and
2005 Ford Thunderbird 50th Anniversary Edition 3.9L
2002-2005 Ford Thunderbird Base 3.9L
2004 Ford Thunderbird Pacific Coast Roadster 3.9L
2005 Lincoln LS Appearance 3.0L
2000-2004 Lincoln LS Base 3.0L
2000-2004 Lincoln LS Base 3.9L
2001-2003 Lincoln LS LSE 3.0L
2001-2003 Lincoln LS LSE 3.9L
2005 Lincoln LS Luxury 3.0L
2005 Lincoln LS Premium 3.0L
2005-2006 Lincoln LS Sport 3.9L
2005 Lincoln LS Ultimate 3.9L
Steve
and
Steve
#94
Sorry to be late to the party, but I just noticed this one. I had one fail on the 03 in 2010 at 80K miles. so 7 yrs/80k mi. It was a "tough get" as the story was Jaguar's supplier in Canada had gone out of business and they hadn't yet resourced it. Found one on the shelf in Houston and had it dropped to Motorcarman's shop and he installed it. I kept the failed one to have rebuilt in the future, figuring the same fate would befall the 05. So far, not an issue at 12 years and 125k mi. but it is safely tucked away on a shelf in a well-marked box and could be rebuilt and returned within a week or slightly more. The telltale chirp it makes gives you nearly a year's warning before it starts shredding the belts, so I should be good.
I've also had the same failure on the Diesel Excursion (150k to 180k mi, don't remember, exactly) and the 95 X300 (18 yrs/137k mi)
Came to browse this thread to determine if Motorcraft YH1504 is the same evap temp sensor as XR83729 for S-Types to VIN N14994? I believe it is and will confirm or deny later, after resolving my 03 issue of occasional hot air from outboard vents while cold air coming from inboard vents.
jaidank (12-06-2016)
#95
Confirmed: Motorcraft YH1504 = XR83729 Evap temp sensor.
Renewed it today. Problem was intermittent, so will probably take a week or so to confirm it has resolved the issue (or a day to deny it)
Measurable difference in resistance readings between old and new at same temp, so I'm hopeful.
The following 4 users liked this post by aholbro1:
#96
I'm looking for the Ford equivalent part # for the reverse parking aid speaker for my 2003 Jaguar S-Type 4.2L V8. Can anyone help?
I saw somewhere that someone successfully used the Ford part, but they never specified the actual part number. I think they said it cost them like $6, instead of $50+!
In my research, it looks like this exact part may be used in lots of different vehicles.
Thanks in advance for any help!
Edit: I found the post I was referring to. It's not in the S-Type forum, but still applies.
https://www.jaguarforums.com/forum/x...2/#post1346495
#97
#99
#100
