Connecting Bluetooth
This is for my car (2005 S-Type) and my phone (Blackberry 8330). If it doesn't work for you, it will give you an idea.
Car:
Enter ##3#*# using the keypad and press the green Send/End icon (“Discover me” appears on the screen)
Phone:
Select "Options"
Select "Settings"
Select "Bluetooth"
Select "Add device"
Highlight Jaguar
Enter PIN 1313 and press "OK"
NOTE: During pairing please use the PIN 1313.
I also have the option of using ##1#*# as the pairing commend. This one won't time out whereas the one using the "3" times-out after about 5 minutes.
Once you've paired the two, they should link up automatically when you get in the car and turn on the ignition. There's a book available. Check:
http://www.jaguar.com/us/en/#/owner_...ent_literature
Eric
Car:
Phone:
Select "Options"
Select "Settings"
Select "Bluetooth"
Select "Add device"
Highlight Jaguar
Eric
Nope... It is an add on accessory... Quick easy way to tell, do you have a microphone on the headliner right next to the overhead console? No mic, no phone.....
Here is a picture of the microphone, it's the little box next to the overhead console.
Car:
Phone:
Select "Options"
Select "Settings"
Select "Bluetooth"
Select "Add device"
Highlight Jaguar
Eric
Car:
Phone:
Select "Options"
Select "Settings"
Select "Bluetooth"
Select "Add device"
Highlight Jaguar
Eric
OK I Also have a blackberry so all this should work, just one question how do i get to the keypad section on the car?? I have the mic in my car so im assuming i should have the same setup as you
There shuld be a button with a phone on it beside your Nav screen on the left
Mine came with a seperate owners manual just for the Blue tooth install.
You might drop by your nearest dealer and ask them, I am sure they will let you know for no charge.
Oh yea, another question, is there a plug and bracket on the underside of your center console door? If there is, then you have the phone module but not the bluetooth module.... I thought all 05's were set up for bluetooth if the phone was installed, but that may not be true...
Maybe we need to confirm that your car has a Bluetooth capability.
In the head lining above the driver and passenger there are two small (smaller than a dime as I recall) circular vented openings. Those are not the Bluetooth microphone.
Instead, above the driver's head is a surface mounted component that is longer than it is wide or height. That's the microphone.
Eric
Eric
The bluetooth module is mounted under the console storage box. The console comes apart real easy. Just take the cover off, then remove the console box. You should see the bluetooth module installed. If it's there it may not be working properly. I would check with a dealer and see if they could help you.
The round vented things aren't speakers. If you don't have the surface mounted object that is about an 1 1/2 inches long by 1/2 in wide and sticking below the headliner by about a 1/2 inch, you don't have Bluetooth. That's the microphone. It'll be easier to tell if Bluetooth is installed from that than from removing the console.
The speakers used are also the entertainment speakers I believe.
Eric
Eric
After I posted the picture he said that he had the mic. That is why I told him to pull the console out to be sure he had the bluetooth module. Bluetooth is really two parts. The simple: There would be a phone module in the trunk and a separate bluetooth module in the console.
My apologies. I didn't see the photo message and he referred to "speakers."
It is certainly strange that the physical evidence (microphone) of Bluetooth is there yet he's getting the message that it's not installed. Why would anyone install the one and not the rest of the system? Curiouser and curiouser....
Eric
Eric
Eric
Eric
And no apologies necessary. I've done a bunch of research on the phone system since that is the one thing I wanted to add. But way more money than I'm willing to spend. Got the SIRIUS system for 50 bucks. Works OK. I also have a Blueant speaker phone for now.
