considering buying 01 s type 4.0
Guest
Posts: n/a
hello from audi forums!
im looking into buying a 01 s type with 70k on it.
from what i read the car has the same transmission the v8 a6 has. zf-5hp24?
in audi this tranny tends to need a rebuild around 80k
does this car have the same problems? usually throws a code (incorrect gear ratio) not sure what the exact code is lol
also i would like to know if there are any other known problems with the car.
like on audi the valve covers and cam chain tensionors go bad and leak oil. are there any known problems with the jag s type 4.0 that i should look into?
also how many mpg do yall get on your 4.0? im expecting to get 24 on the hwy.
It doesn't have the ZF 5HP24.
It has the Ford 5R55N.
But the 4.0 is still a nice car and I think by now you can forget Nikasil issues (few had them, especially by 01, but also it was a long time ago so if it's been running OK for 10 yrs why worry).
Tensioners are a worry if not already updated - ask and find out.
It should have the Ford 5-speed. I find it to be the most reliable component of my 2000 4.0. When things are running right on these earlier models, they are a joy to drive -- the 5 speed is a bit sluggish on kickdown, and has fairly low shift points, but when you put it in "s" mode it comes alive. As mentioned by others, definitely check into whether the timing tensioners on both banks have been replaced with the newer versions. I have learned the hard way that things can get expensive when they fail. If it has CATS, the shocks may be on their way out -- it is much cheaper to replace them with traditional Billsteins and disconnect the CATS system.
Beardy
09-18-2015 10:00 AM
