constant beeping on 2001 model S type
Guest
Posts: n/a
Most of the time, it is a leaking trunk seal (the black rubber you see when your open the trunk). It can also be caused by water leaking through the taillight assemblies. In either case, water collecting in the trunk can play havoc with the car's electronics, just as you've already experienced....
I advise punching a small hole near the battery so even if you think you sealed the boot and it still leaks, the water will have somewhere to drain onto the ground.
When I bought my 2001 S-Type in 2003, The FIRST thing I did was to take my air hammer with a pointed punch and put a hole in the boot floor next to the battery.
A small hole a few millimeters in diameter won't hurt anything and it might save your electronics.
bob gauff
bob gauff
The following 2 users liked this post by motorcarman:
Michael Weill (10-16-2014),
Norri (12-03-2011)
Received 2,263 Likes
stanjag
08-30-2015 10:35 AM
