Coolant Issue.
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
My car had a severe coolant leak. I would go through about 2 large bottles a week. It overheated a few times and I ended up taking it to a shop to get fixed. He reconstructed the coolant reservoir and replaced my transmission lines.
About a week later, the coolant light started coming on again.
This time I took it somewhere else to get fixed.
They replaced my water pump and the hoses.
Only an hour after I left there, my coolant light comes back on.
What is the deal?!
Anything else that could be wrong that is causing this issue?
What is the deal?!
Received 6,309 Likes
Received 2,263 Likes
Is there signs of external coolant leakage? Is the coolant level actually low? Possibly the coolant system still has some air in it.
This is exactly why you simply cannot claim you don't know anything about cars. Because you have now had an expensive lesson and the same problem remains. So is it multiple different problems or the same one that has been improperly done?
You don't know and it will cost you even more money to find out. It is your choice.
One added comment. Repairing the coolant reservoir is a bad idea. The plastic degrades with time and heat. Get a new one and replace it. It will fail again.
You might consider staying only with cars under factory warrantee. Very expensive but again you have made a choice.
jag79 (05-17-2012)
A Jaguar dealer might be a good option. They will be more money. But, they will at least not be doing things like trying to patch a coolant reservoir.
Finally, there are illustrated pages in the owners' manual explaining the meaning of every single warning light on your dash. When a light comes on, there is a reason for it, and you need to know what that reason is. Then, act accordingly.
X308XJR
05-20-2019 06:50 PM
