coolant leak
coolant leak
So as i left the car i noticed the smell of coolant. After a quick look around in the engine area, nothing jumped out at me. The coolant level in the overflow tank was lower than it should be, not low enough to trip sender. I topped it off. Ive seen here and other places where the over flow tank itself leaks due to cracking. Where on the tank due cracks develop? What other areas should i be looking at for a slight/slow leak?
2005 4.2 n/a
2005 4.2 n/a
What model / year is your car?
Anyway, just in case, have a look at this thread:
https://www.jaguarforums.com/forum/s...r-help-109925/
bricklingto (02-04-2014)
The following 2 users liked this post by aholbro1:
bricklingto (02-04-2014),
Norri (02-04-2014)
If its not the overflow tank, it's probably the heater control valve. Two most common coolant leaks. Be careful driving around with a leaky tank. My x350 XJR blew the nipple off the car at a red light and coolant started spewing everywhere......
WhiteXKR's wife's car had a slight leak at the nipple and he ignored the coolant low warning figuring he would fix it eventually. The nipple broke off, car lost all it's coolant, and overheated till it dropped valves in the seats. The Low coolant warning is the ONLY warning you get on these cars.
Take care,
George
Take care,
George
OkieTim
09-08-2015 04:48 PM
