coolant leak
today i smell coolant while driving so i pulled over and the little plastic on top of the tank broke off and coolant was everywhere. i ordered a new tank today has anyone changed this before is it difficult. how do u dissconnect the hose on the bottom of tank i really dont want break it thank u for your help car is 2005 s type v6
jaguar 20:
Please do some searching and also we need what engine you have. Put it in your signature or somewhere. Yes this is pretty common. If you have a V-8 (I am guessing here!!) Be VERY careful of the large hose connection to the upper tank that has a wire retainer!! The wire clip must be pulled back before the hose will come off the tank nipple. Yes it is VERY tight in this area. One guy with a STR changed the top tank and thought everything was OK. The connection blew off while driving, the engine overheated and he burned two pistons destroying the engine. We have not heard back from him since. Last I heard he was into it for over $5K and that was with him doing all the labor!!
Received 6,308 Likes
My first Jag, 2000 stype 3.0, had the same issue. Apparently it was a recall so I'm not sure if you can get your car in to a dealer to see if that was still honored or something, or maybe a cut rate install. Mine was still in the extended warranty phase at the time. But I found out when my fan was coming on and staying on after I left the vehicle and when checked, no coolant in the reservior. The JITS guide would help you, to do it yourself. That's $10 on ebay.
Make sure you use the pink/orange coolent grade.
yeah i fixed it today pretty simple 175 for part at dealer got coolant also at auto store told the guy it was for jag s type model number matched the number on the resuivior tank that was on the bottle of antifreeze but it was not orange or pink more of a yellowish greenish color it was peak antifreeze should this be ok i only used maybe less than half the bottle
Well I guess on how much collant leaked out. In my case, a lot.
As for the coolant type, I don't remember green, etc but it has to be compatible with what you already have in there I would think.
Pink/Orange was the only type I knew was compatible.
Manual:
High temp low to -40, extended life Orange colored, spec WSS M97B44.
You might want to flush and refill your anitfreeze if you haven't done so already. I think they suggest that after 5 years. When I did mine I used Jaguar coolant (which I know is expensive).
Manual:
OkieTim
09-08-2015 04:48 PM
