Coolant level: intermittent idiot light
Last week we had a report of low coolent level. The surge tank showed the level indeed was below the minimum level. I filled the tank to between the "Min" and "Max" levels with 50-50 coolant and water. When I ran the engine, no problem.
It's a week later and my wife is driving home. When she's moving, warning is on. When she stops, light goes out. Interestingly, when pulling the 100 yards up to the house (uphill) after stopping to get the mail, the light stays out.
I've looked under the car and under the hood. There's nothing that looks like a splash or drip field under the hood. Under the car there is a damp area between the right front wheel and the centerline of the engine and just about even with the wheel. That's roughly under the surge tank for the cooling system. However, there's no indication of a puddle or stain when we pull out so I'm sort of guessing that this is A/C condensate.
So, two questions:
1. What issues could be causing the low coolant warning?
2. Could the A/C condensate be causing the spot on the drive? We have several dogs and need to be careful about coolant spills.
Eric
So, two questions:
Eric
Please post the cause when you determine what it is. I'm curious as to whether the plastic coolant tank bottles continue to crack and leak even in the later-model S-Types. I know that was a problem early on, but you'd think that Jaguar would improve its plastics after it became apparent that they needed to....
Well...I went in yesterday and they replaced the surge (expansion) tank. Everything was fine.
Went out this morning and started it only to find "Coolant low" as an error message. Popped the hood and sure enough, the tank was low. I filled it with coolant and drove to work. I'll check before I start it tonight. I'm hoping there was something that made the hot-cold cycle reduce the fluid level. There was nothing in my driveway spot.
So...the mystery continues.
Eric
Eric
I agree - keep checking your coolant level first thing in the mornings and add as needed. They probably did a quick coolant add after replacing your plastic tank and didn't bother to purge any air that may have been gulped into the system as a result. I'm betting that after two or three days of this, you'll be back to normal....
Keep us posted....
Keep us posted....
I added about a pint of 50/50 mix. Last night the level looked a bit low but I didn't add any. This morning I was able to pull the cap and verify it is low but it's not showing alarm. It has the "Min" step still covered. I didn't add any coolant. I want to see if the continued use reduces the level further and throws it into alarm.
I sort of think the bubble theory is what it is now. Yesterday when I found the low level, there was no evidence of a leak around the surge tank. There's also no evidence of spray on the fire blanket under the hood. However, I have a spare pint of the coolant mix with me. Sort of a "Trust but verify" approach.
Thanks. Who would have thought this would turn from an anecdote into a saga?
Eric
Eric
KarimPA
09-12-2015 08:15 AM
OkieTim
09-08-2015 04:48 PM
KarimPA
09-03-2015 07:32 PM
