coolant temperature sensor
My 2001 s type ,4.0 with 56,000 miles has the engine management light glowing. Auto Zone checked the codes and told me it was PO125.I checked the coolant level and it is OK.The car runs perfect.I noticed the engine management light when I drove away from a car wash.What are the symptoms of a bad temp coolant sensor?
Went for a drive this morning and car reached normal operating temp(middle of gauge) in about one and 1/2 mile of driving.Engine runs perfect.Must be the coolant temp sensor. I think I will wait a few days and see if it resets itself.I assume replacing the sensor is not a difficult job.
I will appreciate any other comments.
oldmaned (06-18-2014)
Cheers,
The following 2 users liked this post by xjrguy:
Jumpin' Jag Flash (06-19-2014),
I was having a temp gauge issue…the needle would go to hot, but the car was not overheating….i changed the coolant temp sensor but that wasn't the problem…it turned out the coolant reservoir had a pin hole leak, and it must suck air in and then cause a false reading….changed that and never had a another problem….some guys also refer to it as the digas bottle.
oldmaned (06-22-2014)
