Cooling Fans Electrical Trouble 02 S TYPE 4.0
Got the car from in laws and they're the original owners. It has 110k on it. The ac went out slowly so off to the learning school of DIY for old Jaguars
Replace ac compressor dryer condensor. Fans are working. Worked well for a few weeks and the system wouldn't cool at idle. Fans working and found a leak at service valve, repaired and recharge system. Same thing happens a few weeks later and decided to replace the 2 hoses after knowing they may the originals and the oily residue on 1 of the hoses. After recharging the system the fans won't kick on even with engine temps up. Fans work with direct current and fuses appear to be good. Looking for a wireing diagram for the cooling fans. I've read about the fan module and will be trying to locate it and any relays within engine bay. Any help is appreciated as my wife doesn't like the jeep as much as the jag.
thanks
thanks
The fan module is mounted on the fan cowl itself.
The electrical guides are available for download on the internet.
Gus likely has the info on his site (jagrepair.com).
2001/2002 S-Type electrical guides are the SAME. When the 2002MY car was introduced, we only got a new front cover to the paper guide marked 2001/2002 MY electrical guide, not a new guide. We were instructed to discard the one that had 2001 printed on it and place the new cover on the front.
bob
bob
http://www.jagrepair.com/images/Auto...x2032002en.pdf
See figure 3.2 for the cooling fan.
Did you check the big 80A fuse (#25) in the front power distribution box under the hood?
kulddy
08-15-2015 05:12 PM
DavidMoo
11-19-2012 02:57 AM
