Cost for head gasket replacement?
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
What am i looking at for cost for having the head gaskets replaced on my 03 s type r? I have a small coolant leak under the intercooler and it looks to be a coolant line but i just wanted to know what the aprox cost would be. I understand about head surface condition and other varibles. I just need a ball park cost/hours for a head gasket job. If i did have this done i would go ahead and do the head stud upgrage for my furture plans for more boost. Help please?
Thanks!
Thanks!
I am losing coolant at pretty good rate. Its not going into the crank case as the oils is perfect and not milky. So it is going somewhere and the leak that i have found doesnt seeme to be bad enough to lose that much coolant so fast. So i was just wondering as i was looking for the worst case senario if this leak gets repaired and i am still losing coolant. Its has been really cold here so it is hard to tell if it is coming out the exhaust. There is no visiable coolant nor does it have that sweet smell if it was. That is why i asked.
Thanks for the reply.
styper, welcome to the forums. I would rewrite what your asking abit different and then make a new thread in the "S Section" of the forum. the reasoning is mods don't like double posts.
There are alot of STR guys that really know their poop!! My money for what its worth is going to be the coolant line under the supercharger! Long job and BIG bucks at the dealer.
Stypernva (02-02-2011)
What am i looking at for cost for having the head gaskets replaced on my 03 s type r? I have a small coolant leak under the intercooler and it looks to be a coolant line but i just wanted to know what the aprox cost would be. I will put a pressure tester on it to try to pinpoint leak. I understand about head surface condition and other varibles effect cost. I just need a ball park cost/hours for a head gasket job. If i did have this done i would go ahead and do the head stud upgrade for my furture plans for more boost. Help please?
Thanks!
__________________
Thanks!
__________________
Thanks!
__________________
Thanks!
__________________
Thanks!
__________________
Thanks!
__________________
http://www.youtube.com/watch?v=3suQy44G_B0
Good Luck
![Icon Bike](https://www.jaguarforums.com/forum/images/smilies/icon_bike.gif)
Anyhow, its identical twin is already there, so I'll move and then merge.
Hope you get to the bottom of the problem.
