Cost for rotors for an 06 StypeR
Well I did my brakes at the dealer on the 1st of November and its expensive but then again I just recently bought my 07' STR on september. Total cost just for the front was $900 I KNOW I KNOW!!!!!! OUCH. But mean while start looking for a place that do it cheap but not dirty cheap just remember the saying "You get what you pay for", it happens all the time. Make sure they fix european cars also.
You could turn them if they need it and are within the spec. See the workshop manual
(ebay $6-10)
An 06 likely doesn't have Brembo calipers but make sure you check the correct disc specs (thickness etc)
edit: The discs are unlikely to need turning. As others say, no need to do it routinely. Just check thickness and if OK leave them alone. If getting too thin, replace
(ebay $6-10)
fogey0 (12-01-2010)
Received 2,263 Likes
Not to state the obvious here, but some people don't have the time, tools, skills or even a location to do work like this themselves.
Understood. So they are going to seek a shop to do the work. It's great to go forearmed but in the end they probably will be totaly dependant upon the shop's decisions. Most shops hate owners that know something. Find the one that doesn't and hang on to it. Oh and BTW, pay them fairly.
Warped rotors are pretty much a myth- if pedal pulsations are experienced then it's simply pad material that's been transferred to the rotor surface in 99.9% of cases. Easily removed with a coarse grit sandpaper and angle grinder.
Rotors do not need to be turned as routine mtce, pulsations or not.
Installing new pads can be done yourself in less time than it takes to drive to your local garage. Worth learning how.
It's aimed more at the experienced amateur mechanic. Brakes are a serious safety issue on your car.
There are numerous things that can cause pedal pulsation and or steering wheel jiggle. One of them IS warped rotors but that's not the only one. When it is deposition of pad material sometimes it's easier to just throw new rotors on if they're cheap than it is to screw with cleaning or turning the old ones. My 2001 Sable has very inexpensive rotors and over time it's one of those cars that does develop the pad deposition issue. It was even worse while I had cross drilled rotors on the car.
My 99 K2500 Suburban is a lot more work and I have the rotors turned on the vehicle. That works out very nicely. I do it about every 60K miles.
Other times I've had corrosion develop between the slip-on rotor hat and the hub. When I get new tires or just have them balanced then the rotors on some cars become loose while the wheels are off. If there's junk between the hub and rotor's hat you get the pulsation.
I just put new pads on the 05 STR @ 19K miles and you can see how the OEM pads did a great job of making the rotors thinner but with properly cleaned calipers and new pads with a decent bed-in period worked flawlessly. A shop most likely wouldn't take this approach for a variety of reasons.
So there's no one simple answer to how to do a brake job.
Bob S.
A person that has their mtce. done by either a dealer or local garage would not likely ask either question unless they're simply preparing a budget or expecting that they'll get overcharged.
TypeR rotors, as owners have discovered, are not cheap throw-aways like on many domestic cars. The act of routinely turning rotors as part of a brake job is unnecessary, yet the general public has been conned into believing 'bad things will happen' if it is not done.
I suppose without more info from the OP, his motives for asking the question would only be speculation on my (our) part.
For me, if I've got issues with really bad pulsation then if the rotors aren't like gold I put in the new ones because I like my cars "just so" and I don't want to go back and visit the repair again.
Bob S.
Now you're in my field of 'expertise', having spent 31 years at a major OEM. No offence but your presumption of how things operate in aviation is pretty much the exact opposite, thankfully. My background causes me to disagree with the idea of doing unnecessary work, such as automatically turning rotors, on the vague pretext of legal liability issues.
Rotors need not always be turned....causes them to wear out more quickly...
In California and New Jersey you practically have to sign legal release forms just to use a urinal. So maybe the environment is different in Canada.
Anyway, I know the reasons I've listed are why shops don't just change pads. Obviously it's a waste in a lot of cases but for a lot of people what else can they do.
Bob S.
Back to Rotors
Speakin' of airplanes ... Guys, I think we hijacked this thread pretty thorougly now. Can we get arrested for this?
The 06 STR rotors are maybe not covered on this website as exhaustively as the Brembo style ones have been. They're also inherently less expensive. If you don't find much in the threads here I would get a copy of JTIS, the oh so funky Jaguar maintenance manual, to verify the dimensions because they're different than the Brembo ones. Then when you order rotors from www.cheapestbrakepartsintheuniverse.com you can query them about dimensions so that you get the right ones. The numerous websites out there have the info for the STR rotors all f*ucked up most of the time. If you need the dimensions quickly I can look them up for you.
Bob S.
Bob S.
Umm, that's half a story.
Items that have a time limit (X number of hours, cycles, calender years) are usually relegated to that type of replacement interval because there are no cost-effective and/or non-destructive inspections available to effectively/adequately assess the airworthiness of the component. No use spending $100 to inspect a $50 spark plug and there's not much point in cutting the main spar in half just to find out that there was nothing wrong with it.
Your 172 has what's known as 'hard time' mtce and back in the dark days of aviation when it was certificated, was the only alternative. This is as antiquated as twice a year tune up at Canadian Tire after a 'free inspection'.
Modern aircraft, including all the aircraft types I looked after, use a process called MSG3 to create a basic progressive and on-condition type maintenance program.
Please read here for the basics:
http://www.aviationtoday.com/am/repa...G-3_33062.html
I was a member of several MRB and ISC's for various aircraft types. This is one of the few functions I miss participating in after taking retirement last year. I could tell horror stories about aircraft maintained strictly on 'hard time', but you probably would never want to fly again. I could also give examples of the harm that over-maintenance can do, but that's for another day.
Back on topic, car brake rotors would be and are a perfect candidate for an on-condition program, and in fact aircraft brake rotors are maintained in this manner.
