Could ABS/Traction fault cause hot wheel.
Hi my first post here. I've read various threads which are a great help but they dont exactly cover my situation. Just bought a 1999 S Type 3L V6 manual. Got the following lights permanently on ABS, Traction control fault, Traction Dynamic control and Brake. When I got home after buying the car one of the back wheels was very hot and smelling of brake pad. My first thought was stuck brake caliper causing the hot wheel but on jacking up its not solid but running almost as free as the other back wheel which is ok.
So where do I start trying to remedy this lot. And could a fault with the ABS/Traction control be telling the the brakes to be applied to one rear wheel all the time while I'm driving, to cause the hot wheel. Or could it still be a faulty brake caliper even though its not stuck solid by any means. Meaning I've got a faulty brake caliper and a separate ABS/Traction control fault? Any ideas would be greatly appreciated.
So like I said could the hot wheel and ABS/Traction control fault be all the same fault?
PS After speaking to previous owner he says always had a problem with handbrake adjustment so the Brake warning light could be a separate problem which I'm not too worried about if thats the case.
Chris
Chris
Welcome to the Forum, Chris.
Hope you get the problem sorted soon.
Please take time to visit
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
and introduce yourself so we can all say 'Hello'
There's a thread a mile long here
https://www.jaguarforums.com/forum/g...-%2A%2A-33347/
Many of us a very happy with a cheap bluetooth adapter from EBay
http://www.ebay.fr/itm/Android-Torqu...item3a7b2ac8f5
and an app called 'Torque' running on an Android phone.
Received 2,263 Likes
Even the slightest residual friction will cause a hot caliper. If it was the ABS or DSC there'd be no mistaking it with noise from the former and warning lights from the latter.
Start with the parking brake mechanism, make sure that's free.
You'll have to bare with me, I might be asking stupid questions
but....is the Traction control fault warning, a separate fault from the ABS warning light or are they part of the same? Or, is the possible sticking caliper/wheel bearing (causing the hot wheel) causing the Traction control fault and the ABS fault is a separate issue?
Chris
![Icon Neutral](https://www.jaguarforums.com/forum/images/smilies/icon_neutral.gif)
Chris
Two separate, independent systems. There is a fault warning if either has a problem and an indicator light if the DSC is activated while driving or is turned off by the driver.
Collector1
09-28-2015 03:45 AM
