Creaking Noise/Pinging noise in rear wheel area...?
If anyone could help me on this issue.... When I get out of my car almost everytime, I am getting a creak/Ping noise sounds like in the rim area inside the hub, but is def in the rear suspension area. I just had brand new upper and lower control arm bushings put it as well as new shock bushings. Anyone experience this problem? Maybe some grease needed somewhere? thanks.
Its usually the spring moving on the seat. Try jacking the car up so that wheel is off the ground, supporting the car with a stand and then try turning the spring in its seat. Sometimes just moving the spring back into its proper seated position cures it (there should be a recess for the end of the spring in the lower spring seat).
innzane
09-02-2015 10:08 AM
